 Post subject: WD5000AAKX-00ERMA0
PostPosted: September 6th, 2014, 9:42
The drive in topic spin up normally ( half calibration ) and get ready but no detection. After heads replacement the drive make the same symptoms.
PCB changed but no luck.
Any ideas ?
Thanks in advance.
 Post subject: Re: WD5000AAKX-00ERMA0
PostPosted: September 6th, 2014, 10:24
Media damage?
Have you swapped back heads to donor to see it they still work?
ACELab partner
PostPosted: September 6th, 2014, 10:31
yes I did, and it worked fine.
PostPosted: September 6th, 2014, 10:44
Hello
You have a problem in firmware or head are not compatible.
Good Luck
Récupération de Données
PostPosted: September 6th, 2014, 10:48
FW checked after hot swap mod02 was corrupted. I believe heads are compatible too. Because after heads replacement the drive detected with full model and capacity but with slow responding and I tried to connect to SD doctor but this problem happens before I tried anything.
PostPosted: September 6th, 2014, 13:49
The drive is ID'ed right after head swap?
What's the problem after, than?
Slow responding?
ACELab partner
PostPosted: September 7th, 2014, 10:16
Yes. But with slow responding then I connect the drive to SD doctor to fix this.
When I powered off the drive and power on again the drive become undetectable and make half calibration and couldn't load normally.
PostPosted: September 7th, 2014, 18:12
Most probably you have bad media. Meybe media damages heads too
Can you try to backs heads to donnor drive another time¿
If not correcty works, then your media is badly
PostPosted: September 8th, 2014, 9:37
I tried that already and the donor drive works normally.
PostPosted: September 8th, 2014, 10:17
Opps
Then i suppose your problem is about FW.
Can you upload FW, maybe anybody can take a look.
PostPosted: September 8th, 2014, 10:21
I am waiting for a donor for hot swap to access SA
PostPosted: September 8th, 2014, 10:34
clever idea; maybe you are lucky
please report us
Users browsing this forum: Google [Bot] and 214 guests
