 Post subject: In Need of a Donor Drive ST3000DM001
PostPosted: September 5th, 2014, 18:30
I cannot find a donor for this drive. Would be much appreciative if anyone has one.
ST2000DM001
W1E
9YN164-568
WU
Thanks.
 Post subject: Re: In Need of a Donor Drive ST3000DM001
PostPosted: September 8th, 2014, 17:23
Just use any ST2000DM001 with S/N: xxE
Good luck!
PostPosted: September 8th, 2014, 17:52
I thought you needed the first three letters of the model and/or the complete part number?
PostPosted: September 8th, 2014, 17:54
And Site Code?
PostPosted: September 8th, 2014, 20:04
Not "or", as I learned recently with this drive. Donor Drives' criteria say:
Hard Drive Match Criteria (for Head Stack Assembly replacement or Platter Swap).
1. Full Model Number. Example: ST9640320AS, ST31000528AS
2. Site Code. Example: TK, AMK, KRATSG, WUXISG
3. Full part number or first 3 characters in serial number.
Example: 9Y7389-301, 9JU138-302, 5MA84KC2, 9ND29XWG
4. Firmware. Example: CC44, 0005HPM1
But if the first 3 characters of the serial number don't match, you may end up with the wrong number of heads.
PostPosted: September 8th, 2014, 20:21
Larry. Not sure if I understand you. Do you mean I need both P/N and first three letters of the S/N?
PostPosted: September 8th, 2014, 20:52
You need the first three characters of the serial number, as well as other parameter matches. I understand that a variety of criteria as feasible, some of which one would never guess appropriate.
Here are HDDSupplier's criteria:
Head Stack Assembly Exchange Part Requirements
1. First part of model number and 2 or 3 middle characters of the second part. Example: WD6400AAKS-65A7B0, WD10TMVW-11ZSMS1
2. Country of Manufacturer. Example: Product of Malaysia or Made in Thailand
3. DCMs 5th character. Try matching 4th, 5th, 6th, 7th character if possible. Example: EANNHV2MA
4. Closest date of manufacture possible. Preferably within 3 months.
harddrive-repair.com's criteria are at: http://www.harddrive-repair.com/hard-drive-parts.html
PostPosted: September 10th, 2014, 6:09
Hy
From my experience if the model firmware and site code are the same you have a good patient.
As the site code changes it will also change the serial number, and of course head map.
PostPosted: September 11th, 2014, 5:16
Hello ddrecovery!
Here it is what i mean:
"According to fzabkar in Seagate: Forums: 2TB ST2000DM001 Barracuda from Seagate seriously cripled through redesign in 3/2012 or 4/2012, the S/N (serial number) on the label of your Seagate Desktop HDD ST2000DM001 contains information about the number of plates.
Check the third character of the S/N, F is 3 while E is 2 platters.
The first character of the S/N is the manufacture of head stack components.
S – SU – Suzhou in China
W – WU – Wuxi in China
Z – TK – Teparuk in Thailand"
http://amigotechnotes.wordpress.com/201 ... al-number/
PostPosted: April 14th, 2017, 12:09
Criteria for donor search
hey guys,
sorry for jumping on this old thread, but would really really like some imput.
For a clicking HDD acquired some years ago, with this info on casing :
Model number: ST2000DM001
Part number: 9YN164-568
Serial number: W1F04C2V
Firmware: CC96
Site Code: WU
Date Code: 12087
DOM: 08/2011
Product of China
100645422 REV A on the PCB
100622804 on the barcode sticker
Barracuda series
SKU: 20003
whats best criteria for donor searching ?
Matching part number ?
thank you for your time !
PostPosted: April 14th, 2017, 14:34
Does this help?
Https://www.recoveryforce.com/seagate-h ... -headmaps/
Users browsing this forum: Google [Bot] and 48 guests
