 Post subject: WD3200BPVT-22z SATA drive password unlock or recovery
PostPosted: August 27th, 2014, 17:24
WD3200BPVT-22z sata drive has hdd password set on gateway laptop
after trynig to figure out how to finally get scripts into the script directory and get a working image
mhdd gives me “error: no drq” when running any of the scripts (.dump,.dump2,etc..)
trying to use zu.exe doesnt work after a few hours , put it in a pentium 4 machine also no go
even tried victoria hdd tool on hirens to unlock
also default WDCWDCWDCWDC and h2oinsyde password not working
i would like to see what password was set , any other way to dump the bin?
 Post subject: Re: WD3200BPVT-22z SATA drive password unlock or recovery
PostPosted: September 3rd, 2014, 18:43
anyone?
PostPosted: September 4th, 2014, 8:06
Ask the owner for the password.
PostPosted: September 4th, 2014, 20:52
Thanks Captain Obvious.
PostPosted: September 7th, 2014, 9:37
If you can prove ownership? just take or send it to a DR Pro who has the tools & knowledge to do this for a fee.
is the data important? if not & you want to try DIY then you will need to do a lot of researching.
Members on this forum cannot prove you are the owner of the hdd drive & helping you to bypass the password could end them in a lot of trouble if the drive turns out to be stolen. Please note I am not saying that it is so no offence is meant.
Loki
PostPosted: September 16th, 2014, 15:43
I should have mentioned in first post , this is not my computer, I do pc repair and it is for a customer of mine. I'd just assume pull the drive and install a new one and reinstall windows, I figured Id help the guy not incur the cost of doing so. :lol:
PostPosted: September 16th, 2014, 17:14
if data is not significant, exchange drive and reinstal o.s.
because as said here we can not verify owner
good look
Users browsing this forum: No registered users and 14 guests
