 Post subject: WD 2TB LL format
PostPosted: September 21st, 2014, 16:32
I dropped a WD 2 TB green hard drive and now it has a lot of bad sectors, I was able to recover all the files off it and wanted to lock out the bad sectors, so I tried several disk checking programs to fix or lock them, Windows chkdsk, paragon, eseus, mini tool. All got so far then stopped. I was able to creat and make a 200mb partition and format it and check it.
So I decided to start over with a ll format and found HDD LL format and started it but it was slow, so I purchased it and now its running but I can not get any reading of the speed. Its been running 20 minuets and its only one 87,000 sectors, but the speed mbs = 0, I did see it jump to 0.1 once. I am connected directly to the mother board on a amd 8 core 3.1ghz cpu with 4gb of ram. From reading this forum I should get several hundred MB's speed.
Any idea why mine is so slow? I have rebooted and disabled every unessential program.
 Post subject: Re: WD 2TB LL format
PostPosted: September 21st, 2014, 16:57
The drive's firmware may have been affected by the accumulation of bad sectors. Also, there is a possibility the mechanics are weak.
Seel it for parts. Once dropped, likely no longer reliable.
 Post subject: Dropped WD 2TB, LL format
PostPosted: September 21st, 2014, 17:06
larrylwill wrote:
I dropped a WD 2 TB green hard drive ... I was able to recover all the files off it
If that was a real drop and not a few centimeters, then you're a lucky person.
Now you have a hi-tech door stopper, keep it as your lucky mascot. I doubt anyone here will recommend you to re-use the drive somehow else.
PostPosted: September 21st, 2014, 17:18
I wouldn't use that drive for storage, but it might make a useful subject for study.
I would begin by reading the "ROM" and firmware modules (SA):
http://sediv2008.narod.ru/Easy3.9Passwo ... 567890.rar
MOD 34 is the G-list and MOD 32 is the relo-list. These should tell us which head(s) were damaged.
PostPosted: September 21st, 2014, 17:43
What is that program ? What is the name of it?
I can open and extract.
I ran it in a sandbox but get an error. DIV has stopped working.
PostPosted: September 21st, 2014, 20:10
http://sediv2008.narod.ru/Settings.rar
PostPosted: September 22nd, 2014, 18:29
DIV Has stopped working
Here is the log. I also checked for an online solution and got another error message.
Exception EOlesSysError in module SeDiv.exe at 000E2941. Invalade window handel.
Im running Win 7
Problem signature:
Problem Event Name: APPCRASH
Application Name: SeDiv.exe
Application Version: 3.9.7.5
Application Timestamp: 2a425e19
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.18409
Fault Module Timestamp: 53159a86
Exception Code: 0eedfade
Exception Offset: 0000c42d
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 5ac6
Additional Information 2: 5ac69eafdcbbf60109f54d765e15a79f
Additional Information 3: e41a
Additional Information 4: e41a2d7812f2206bc6f17352c9ac95e8
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
PostPosted: September 22nd, 2014, 18:30
I sent a reply but got the message it has to be approved by a moderator for some reason. I included the error message DVI has stopped working and the log that I got.
PostPosted: September 22nd, 2014, 18:44
Use Windows XP instead, if you have it.
PostPosted: September 22nd, 2014, 19:17
I tried it in compatibility mode, still wont run, I have a computer on a piece of equipment with a copy of ME on it I will try later.
Users browsing this forum: No registered users and 121 guests
