 Post subject: ix4-200d RAID recovery help
PostPosted: September 22nd, 2014, 9:38
Last week a drive died on our ix4. I replaced the drive, it started to do its rebuilding, I left it go overnight. The next day I have emails from it, first saying it was finished, then saying a drive had an error (not the one that I replaced) that was fixed and then a third saying ALL drives had been replaced. I rebooted it and it just wants to confirm overwriting the what it thinks are new drives. Didn't do that of course. I've been trying to many days to get at the data using a tool called iRecover. I finally got it to give me a folder/file tree to look at but it is a mess so doesn't seem like a good option. Looks like i'd basically have to re create every folder and copy files back individually to get it back to normal.
I have seen some posts here where DR-Kiev has remoted in to other's IX4s and fixed them. I'm hoping this is an option and he can contact me. Or if anything else has any suggestions, please let me know.
thanks
Ryan
 Post subject: Re: ix4-200d RAID recovery help
PostPosted: September 22nd, 2014, 9:40
thanks
Ryan
Check you PM
Angel Data Recovery
PostPosted: September 22nd, 2014, 9:43
I you have not skills on data recovery i would say contact with a pro, but if you have it maybe RecalinMe RAID recovery can help you.
http://www.freeraidrecovery.com/download.aspx
Note: if you need help we can help you remotelly. contact me on that case.
PostPosted: September 22nd, 2014, 9:53
thanks
Ryan
Check you PM
Can you PM me an email address? I do not seem to be able to reply to a PM. I do not have skype currently. Thank you for the quick response.
 Post subject: Iomega ix4-200d RAID recovery
PostPosted: September 22nd, 2014, 10:14
ryanmvd wrote:
Last week a drive died on our ix4 ...
then saying a drive had an error (not the one that I replaced) that was fixed and then a third saying ALL drives had been replaced ...
Did you individually check that other drives are indeed OK?
It may happen that you will need to create an image of each drive to proceed, but issues with some particular drive(-s) will prevent you from doing so. And that may affect at least the quality of results or RAID recovery overall.
For now this job looks pretty doable, but if necessary, please feel free to contact me as well, we can also help recovering this StorCenter remotely.
PostPosted: September 22nd, 2014, 10:43
I do see the SMART status for one of the drives is "caution". Does this indicate anything useful?
These two are flagged:
C5 100 100 __0 000000000001 Current Pending Sector Count
C6 100 100 __0 000000000001 Uncorrectable Sector Count
(2) ST31000520AS
           Model : ST31000520AS
        Firmware : CC37
   Serial Number : 5VX10R9T
       Disk Size : 1000.2 GB (8.4/137.4/1000.2/1000.2)
     Buffer Size : Unknown
     Queue Depth : 32
    # of Sectors : 1953525168
   Rotation Rate : 5900 RPM
       Interface : Serial ATA
   Major Version : ATA8-ACS
   Minor Version : ATA8-ACS version 4
   Transfer Mode : SATA/300
  Power On Hours : 35076 hours
  Power On Count : 34 count
     Temparature : 28 C (82 F)
   Health Status : Caution
        Features : S.M.A.R.T., APM, AAM, 48bit LBA, NCQ
       APM Level : C0C0h [ON]
       AAM Level : FE00h [ON]
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 119 _99 __6 00000DB4D93C Read Error Rate
03 _96 _96 __0 000000000000 Spin-Up Time
04 _98 _98 _20 000000000A1E Start/Stop Count
05 100 100 _36 000000000000 Reallocated Sectors Count
07 _81 _60 _30 000008BD5D43 Seek Error Rate
09 _60 _60 __0 000000008904 Power-On Hours
0A 100 100 _97 000000000000 Spin Retry Count
0C 100 100 _20 000000000022 Power Cycle Count
B7 100 100 __0 000000000000 Unknown
B8 100 100 _99 000000000000 End-to-End Error
BB _75 _75 __0 000000000019 Reported Uncorrectable Errors
BC 100 100 __0 000000000000 Command Timeout
BD _97 _97 __0 000000000003 High Fly Writes
BE _72 _50 _45 00001C1B001C Airflow Temperature
C2 _28 _50 __0 00110000001C Temperature
C3 _46 _22 __0 00000DB4D93C Hardware ECC recovered
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
F0 100 253 __0 9F1800007D7D Head Flying Hours
F1 100 253 __0 0000CB86AE98 Total Host Writes
F2 100 253 __0 00000E85EB9A Total Host Reads
 Post subject: StorCenter ix4-200d RAID recovery
PostPosted: September 22nd, 2014, 11:15
Current Pending Sector Count = number of sectors, for which drive hasn't decided yet whether they're unreadable or not. Later upon the results of reading attempts, drive can either remove them from "pending" list or do a remap. Basically, those sectors are the "candidates" to be remapped.
Uncorrectable Sector Count = Number of read/write errors drive has been unable to correct. Obviously bad when it's growing.
Generally, having 1/1 for these attributes isn't totally terrible, but this is the drive to keep an eye on.
If during your own recovery attempts you've read all the raw data stored on that drive at least once and attributes above haven't changed, then it is likely to survive the data extraction from it during recovery.
But if you don't feel imaging that drive would be too much hassle, then you can surely do so, that wouldn't hurt.
PostPosted: September 22nd, 2014, 12:13
Banned User
bad option to check these info if data is require go to pro or contact me on skype: ontrack86 RAID recovery is not easy at all.
PostPosted: September 22nd, 2014, 12:34
Too late, the guy found what he was looking for .
BTW How much ontrack guys charge for remote raid help?
Angel Data Recovery
PostPosted: September 22nd, 2014, 12:47
Yes copying files to an external drive now. Thank you DrKiev for your quick and excellent work!
PostPosted: December 19th, 2014, 13:53
I have the same issue my IX4-200d states "4 new drives with existing data" after a failed update to ix4-200d-ix4-200d-2.1.44.30050....I refuse to check the box "Authorize overwrite" of all my data..is there a way to re-establish the raid config?
PostPosted: December 19th, 2014, 14:15
DR-Kiev, please contact me
PostPosted: December 19th, 2014, 15:37
If nothing more destructive than firmware update has been done, then this NAS appears pretty recoverable.
If necessary, I'll be glad to help with it remotely.
Users browsing this forum: No registered users and 73 guests
