 Post subject: Seagate SSHD ST1000LM014
PostPosted: September 23rd, 2014, 4:06
Know anybody problem of this HDD?
It doesnt spin, and i post messages from terminal
ERROR:  Flash LED 9C1C - No clumps available  - cannot get new active clump
Clump Parametrics:
                    Clump = 0264
                 DataType = 00E0
                 ModeFlag = 01
               EraseCount = 000007E3
           EraseFailCount = 00
         ProgramFailCount = 00
            WeakReadCount = 00
    UncorrectableECCError = 00
---SOC PSM Command History---
Cmd#/PsmCmd    Clump     Offset     Length     LbaMid     LbaLow   LbaBits39To32 Options   Status    DestClump  DestOffset
     000A       0264       0000       0001       0000       000E       0000       8000       0021       075F       E010
 Post subject: Re: Seagate SSHD ST1000LM014
PostPosted: March 2nd, 2015, 13:03
I have a SSHD with this problem too.
Could anyone help me?
Here it is the terminal message:
Clump Parametrics:
                    Clump = 00CD
                 DataType = 00D0
                 ModeFlag = 01
               EraseCount = 00000AE8
           EraseFailCount = 00
            WeakReadCount = 00
     000A       00CD       0000       0001       0000       000E       0000       8000       0021       8145       6FE1
PostPosted: May 26th, 2015, 17:49
Hello, Saltwater,
yes, I can help with this drive. It seems we are not too far from eachother...
PostPosted: July 11th, 2017, 16:56
Hello, were you able to defeat this mistake? If you could, then tell us how it can be fixed. Thank you
PostPosted: July 11th, 2017, 18:44
yes, i've done several of these drives since then.
How: find error in firmware and correct it.
PostPosted: July 12th, 2017, 5:10
SSHD drive, problem with NAND content. Possible to fix.
PostPosted: July 12th, 2017, 14:45
Can you help with the recovery of this disk?
PostPosted: July 13th, 2017, 2:18
sure, but i need physical access to the drive, ie i do not do it remotely.
PostPosted: July 13th, 2017, 13:20
Sorry, physical access is unrealistic, very far. Which version should I look at? I'll try to raise it myself
PostPosted: July 13th, 2017, 13:34
eh, do you live in some different galaxy or what? :)
i get drives from perfectly opposite side of the planet too.
I don't get what you are asking for.
