 Post subject: segate terminal
PostPosted: September 25th, 2014, 6:51
1024k x 16 DRAM
NHAWK - 1_Disk S-LE 11-14-07_16:30
ERR A6: App Code
F>
need help witch command i put on terminal
 Post subject: Re: segate terminal
PostPosted: September 25th, 2014, 9:56
can you report here about drive info and problems
PostPosted: September 25th, 2014, 11:04
hard disk is not detected in bios
PostPosted: September 25th, 2014, 11:22
Have you changed PCB or replaced heads?
PostPosted: September 25th, 2014, 23:44
NO I HAVE NO CHANGED PCB
PostPosted: September 26th, 2014, 5:29
CAn you repor all info together
show info about HDD
report us about sounsd, spining,
what are you do till now?
thaks
PostPosted: September 26th, 2014, 7:37
how to clear smart and which command to get T/
PostPosted: September 26th, 2014, 17:10
you need read responses
you must say with drive do you have in your hands.
