 Post subject: ST1000DM003 Not seen in the BIOS or the operating system
PostPosted: September 29th, 2014, 16:39
I have on my desk Seagate Barracuda 1000GB HDD
ST1000DM003 FW: CC4C with the following output on the
terminal:
Boot 0x40M
spin Up
TCC-0020 [0x000065B4] [0x00006A20] [0x00006E8C]
Trans.
rst 0x40M
MC LPC Internal Process
spin Up
TCC-0020
(P) SATA Reset
MCMTFileHandler: EXCEPTION: Failed MCMT read request
MCMainPOR: EXCEPTION: SIM aborted prior to MCMT read
MCMainPOR: EXCEPTION: Failed BY General
MCMainPOR: Disabled Feature ...
Total AC8, AA0 Head, Tail 28 Retry Status 0 0
Total AC8, AA0 Head, Tail 28 Retry 0 1 Status
Total AC8, AA0 Head, Tail 28 Retry 2 Status 0
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000089999!
InitiateMarkPendingReallocateRequest for disc_lba: 000000000008999A!
InitiateMarkPendingReallocateRequest for disc_lba: 000000000008999B!
PowerState = IDLE1
PowerState = IDLE2
APM disabled by Sport
ASCII Diag mode
F3 T>
Not seen in the BIOS or the operating system.
Allows entry of commands, batch passed all
B10... B22, N1, etc. This hdd is from a friend who tried to
repair found no solution and gave it to me for
to experiment with it. Any idea what it may be and as
fix. Any suggestions can be tested disk
contains no information. Thanks in advance GURUS
 Post subject: Re: ST1000DM003 Not seen in the BIOS or the operating system
PostPosted: October 1st, 2014, 11:12
PCB is fine ? Send photos.
Check heads resistance, I think it was this command, wait for advice :D :
T>/7
7>X
PostPosted: October 1st, 2014, 18:37
yes it is the command and the output was:
F3 T>
ASCII Diag mode
F3 T>/7
F3 7>X
Head 00 Resistance 00D9
Head 01 Resistance 014C
F3 7>
any idea
PostPosted: October 1st, 2014, 18:43
I thing the heads are good, i can read and write, i was thinking in firmware bug but i don“t know how read firmware using the terminal or how verifier it.
PostPosted: October 2nd, 2014, 0:51
/T> m0.2.2.....22
/1
N1
After this command your hard disk show in bios :)
PostPosted: October 5th, 2014, 16:33
Sorry but I'm not sure use that command on another disk than 7200.11. But I used m0,6,3,,,,, 22, N1 and F,, 22 and the disc still BSY. Any other suggestions. Thank you all for the help.
PostPosted: February 23rd, 2015, 7:14
Have a similar problem.
Following is the TERMINAL O/P
It Reads Mods COPY 0 (1B) And COPY 1 ( 1B, 93, 35 )
Can not Read COPY 0 ( 28, 93, 35 ) And COPY 1 ( 28 )
Possibly SA area is BAD, Any suggestions in here.
Boot 0x40M
Spin Up
TCC-001C[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001C
MCMainPOR: EXCEPTION: POR Failed General
MCMainPOR: Feature Disabled...
Starting LBA of RW Request=0000000000088996 Length=00000174
ProcessRWError -Read- at LBA 0000000000088996 Sense Code=C3160080
Starting LBA of RW Request=000000000008899A Length=00000170
ProcessRWError -Read- at LBA 000000000008899A Sense Code=C3160080
Starting LBA of RW Request=000000000008899E Length=0000016C
ProcessRWError -Read- at LBA 000000000008899E Sense Code=C3160080
Starting LBA of RW Request=00000000000889A2 Length=00000168
ProcessRWError -Read- at LBA 00000000000889A2 Sense Code=C3160080
Starting LBA of RW Request=00000000000889A6 Length=00000164
ProcessRWError -Read- at LBA 00000000000889A6 Sense Code=C3160080
Starting LBA of RW Request=00000000000889AA Length=00000160
ProcessRWError -Read- at LBA 00000000000889AA Sense Code=C3160080
Starting LBA of RW Request=00000000000889AE Length=0000015C
PostPosted: December 29th, 2015, 6:31
i got same problem.. my disk is ST1000DM003 CC4B
Please share the solution or I'll do it Insha'Allah. :)
Boot 0x40M
Spin Up
TCC-0020[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
Spin Up
TCC-0020
(P) SATA Reset
(DOS) Table Read FAIL
DOS: MAGIC CONFIG NUMBER MISMATCH
(DOS) Requesting File Save
Starting LBA of RW Request=0000000000087CE6 Length=00000024
ProcessRWError -Read- at LBA 0000000000087CE6 Sense Code=43110081
Starting LBA of RW Request=0000000000087CEA Length=00000020
ProcessRWError -Read- at LBA 0000000000087CEA Sense Code=C3160080
Starting LBA of RW Request=0000000000087CEE Length=0000001C
ProcessRWError -Read- at LBA 0000000000087CEE Sense Code=43110081
Starting LBA of RW Request=0000000000087CF2 Length=00000018
ProcessRWError -Read- at LBA 0000000000087CF2 Sense Code=43110081
Starting LBA of RW Request=0000000000087CF6 Length=00000014
ProcessRWError -Read- at LBA 0000000000087CF6 Sense Code=43110081
Starting LBA of RW Request=0000000000087CFA Length=00000010
ProcessRWError -Read- at LBA 0000000000087CFA Sense Code=43110081
Starting LBA of RW Request=0000000000087CFE Length=0000000C
ProcessRWError -Read- at LBA 0000000000087CFE Sense Code=43110081
Starting LBA of RW Request=0000000000087D02 Length=00000008
ProcessRWError -Read- at LBA 0000000000087D02 Sense Code=43110081
Starting LBA of RW Request=0000000000087D06 Length=00000004
ProcessRWError -Read- at LBA 0000000000087D06 Sense Code=43110081
ASCII Diag mode
F3 T>
F3 1>N1
DiagError 00012001
F3 1>
Users browsing this forum: Google [Bot] and 48 guests
