 Post subject: Seagate 7200.12 doesn´t spin
PostPosted: October 7th, 2014, 8:30
I had a Seagate 7200.12 with broken heads. Surfaces OK.
After head swap with compatible donor, the disk is not spinning when power up.
Motor is not stucked and I am able to gently move the heads manually.
Any idea? Suggestions will be welcome
 Post subject: Re: Seagate 7200.12 doesn´t spin
PostPosted: October 7th, 2014, 8:42
What was original Problem?
Have you got any log from serial conecttion?
PostPosted: October 7th, 2014, 9:37
The disk had one head broken.
No error message on terminal, just normal F3 T>
PostPosted: October 7th, 2014, 13:45
Did it spin with original heads?
Could it be a PCB issue?
My firmware database:
PostPosted: October 8th, 2014, 3:41
if help wanted, you need report here more info about case.
i am sorry.
PostPosted: October 8th, 2014, 7:43
Motor was spinning with original heads. I also change PCB and the same result ...
PostPosted: October 8th, 2014, 8:18
i think there are problem with new heads
but you can connect terminal
and post log terminal here
http://www.hpwlab.com
PostPosted: October 8th, 2014, 8:46
Terminal output:
ASCII Diag mode
F3 T>/2
F3 2>Z
DiagError 00005014
F3 2>U
DiagError 00005014
F3 2>V40
LED:000000CE FAddr:0029F05
Rst 0x20M
ASCII Diag mode
F3 T>V40
Rst 0x20M
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>V1
Rst 0x20M
ASCII Diag mode
F3 T>/7
F3 7>X
PostPosted: October 8th, 2014, 9:17
Try to power on the drive with insulated pcb HDA (i mean insert a piece of paper between pcb and heads).
Do platter spin without HDA?
PostPosted: October 8th, 2014, 17:18
viewtopic.php?f=1&t=28605&p=196767&hilit=gasket#p196767
Users browsing this forum: No registered users and 283 guests
