Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD5000AAKS disconnects and reconnects constantly in Wind
PostPosted: October 7th, 2014, 10:09
Finally i reprogram the WD3200AAJS pcb and leave the 8MB DRAM ic.
Drive boot ok but a bit slow, take an image with Media Tools Pro, no bad sectors, check disk(image) for correct the problems on filesystem caused by continuous disconnects-reconnects.
Now drive is ok and data accessed!
Last thing is to replace DRAM on old pcb to find out if was the reason for disconnects..
Thanks all of you for help and support! :D
PostPosted: October 7th, 2014, 12:25
I would compare the voltages at J1.
PostPosted: October 7th, 2014, 23:20
I hope by "accessed" you mean backed up to another drive!
PostPosted: October 9th, 2014, 11:41
This was an early step, before reprogram! Had check voltages at J1 from AAKS pcb and compare them with AAJS pcb.
Was exactly the same!
Now when i find time i will replace DRAM from AAJS to AAKS to see what happens, till the end of week i guess!
Yes, after image creation on another drive, filesystem was repaired and all data is ok on cloned drive!
Patient(with donor pcb) needs filesystem repair or format and original pcb needs time to figure out the cause!
I'll do it, but is 2nd priority now! ;-)
PostPosted: October 9th, 2014, 20:42
Great news, glad you got your DATA Back!
Users browsing this forum: Google [Bot] and 86 guests
