Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: ST3000DM001 - 9YN166 Drive not detect, Spin Up, 11Click'
PostPosted: October 15th, 2014, 0:29
@pikus_09, all the pros are telling you what you don't want to hear. If you wish to eliminate the slim possibility of a PCB failure, then try transferring your ROM to a replacement PCB.
Best of luck.
PostPosted: October 15th, 2014, 17:06
Ok, Franc, but analyzing batch ROM disagree entries is damaged portion adaptyw, so I do not think anything will transfer ROM.
PostPosted: October 16th, 2014, 4:34
pikus_09 wrote:
I try to read the contents of the ROM, it always de-soldered IC with PCB, never vice versa.
btw. And also I have a suspicion that a change in the firmware of CC4B on CC4H hurt this disk.
Was a "forced update" not suggested by Seagate by a chance and done by you? 8)
PostPosted: October 16th, 2014, 5:35
because I have such a rule amendment if it goes out, always update to be downloaded to the latest version, and so it did in this case. Everything was successful, but equally 8days, hard disk ceased to be visible through the BIOS, system and terminal throwing Fail SERVO OP = 100 Resp = 0007.
And pretending to load ROM sail caught as messed up this modification proposed by the seagate. Sorry for my english.
PostPosted: October 17th, 2014, 6:03
@pikus_09, your ROM is OK. If it were not, then the drive wouldn't spin. Instead you would see a checksum error in the terminal log, as in the following thread ...
viewtopic.php?f=1&t=29164
Anyway, your ROM consists of two similar halves, and each half consists of several sections, either code or adaptives (RAP, CAP, SAP). These adaptives are unique to your drive. For example, the CAP contains the drive's serial number.
Here is a comparison of the contents of each section:
ID  start    end  comparison
        0     47  different   header
16     48     4F  different
15     50    24F  different
0E    250    65F  identical
10    660  1B0C7  different   code - 2nd half of ROM replaced by CC4H update
06  1B0C8  244D7  identical   Read Adaptive Parameters (RAP)
04  244D8  246E7  identical   Controller Adaptive Parameters (CAP)
05  246E8  296FF  identical   Servo Adaptive Parameters (SAP)
03  29700  3EEFF  different   code - 2nd half of ROM replaced by CC4H update
0B  3EF00  3FFFF  identical
There are some differences, but these appear to be normal. In fact the differences in at least two of the code sections are due to the CC4H firmware update. ISTM that firmware updates are written to the second half of the ROM.
Barracuda (1TB/disk platform) Firmware Update:
http://knowledge.seagate.com/articles/e ... Q/223651en
http://www.seagate.com/staticfiles/supp ... GRCC4H.iso
Header from update (GRCC4H6H.LOD, offset 0x200)
00000200  0A 0E 00 00 68 06 00 00 00 00 00 00 F4 21 04 00  ....h.......ô!..
00000210  63 73 69 44 00 00 63 83 48 8F 00 00 20 FF FF FF  csiD..cƒH... ÿÿÿ
00000220  16 48 00 00 15 50 00 00 0E 50 02 00 10 60 06 00  .H...P...P...`..
00000230  06 C8 B0 01 04 D8 44 02 05 E8 46 02 03 00 97 02  .Ȱ..ØD..èF...—.
00000240  0B 00 EF 03 00 00 00 04 00 00 00 00 70 A5 00 00  ..ï.........p¥..
PostPosted: October 17th, 2014, 14:20
Welcome franc, now for example. Plugged this drive and is a slight improvement, ie, the drive ejects FaiL servo op = 0100 resp = 0007 each time you click, and so ten times.
Previously, the drive clicked 11 times and log start throwing Fail servo op = 0100 resp = 0003, then fail servo Op = 0100 resp = 0003 Terminal obviously locked. sorry for my English.
Ps. So you're saying Franc that my ROM is ok. Okay, I was hoping that, however, is freaked out.
PostPosted: October 23rd, 2014, 11:55
Hello again, but it turned out that the ROM is good, and
PCB is damaged, Bad MCU.
PostPosted: October 23rd, 2014, 15:28
Boot 0x40M
Spin Up
FAIL Servo Op=0100 Resp=0007
ResponseFrame EB00 0055 03B4 2FC0 0008 0000 0000 0000 0F3E 0000 0000 0000 0000
0000 0000 0000 13E9 70C4 FFFF 2000 DC0C 0000 0000 3F0F 0000 3F0F 0000 2247 0000
0020 001E 0007 0010
FAIL Servo Op=0100 Resp=0003
ResponseFrame E500 0058 03B4 2FC0 0008 0000 0000 0000 0F3E 0000 0000 0000 0000
0000 0000 0000 13E9 70C4 FFFF 2000 DC0C 0000 0000 3F0F 0000 3F0F 0000 007F 0000
0020 001E 0004 0000
0020 001E 0004 0000.
Seen this message a thousand times, and it was always bad read/write heads or media damage. Stop wasting time playing with the PCB, you're just making it worse.
PostPosted: October 23rd, 2014, 17:33
Ok, So at the end, I did the test. He dialed the PCB from the disk and strapped into the terminal. And what I saw !? FAIL Servo OP = 0100 RESP = 0003 10 times.
Afterward, the strapping another PCB from another terminal Segate worked, so here suggests faulty PCB (BAD MCU).
So I personally do not think that in my case fell heads.
PostPosted: October 23rd, 2014, 21:16
Hello
I give you the new .I changed the drive head and I can recover data from my client. :P
good luck
PostPosted: October 24th, 2014, 19:05
For me, the PCB is Bad, Bad MCU, there are different cases of this error, some actually head fell another PCB.
PostPosted: January 6th, 2015, 2:25
hvd wrote:
Hello
good luck
How did you manage a successful head swap. We have burnt through many donors with Seagate DM series drives. Is there something I'm missing?
PostPosted: January 18th, 2015, 15:01
Hello i'm live same problem
Before this error hdd power down and power up possibly 20 times and stopped last time
I can try this post suggestions but everything is normal/fine
I have another bad hdd same p/n etc.
Try board change but same status for clicks
This is showing problem has mechanical possibly plates/motor jam
And last chance open drive and see problem
Upper head break and jamming between head arm and upper plate
This case need for me a head change operation following days
hdd is died with suicide
picture is attached
PostPosted: January 18th, 2015, 15:54
Wow, usually google translate can at least make out one or two intelligible sentences on a post that long. But I can't understand anything he's saying. :cry:
PostPosted: January 18th, 2015, 15:56
ioz wrote:
picture is attached
OK, I understood that part.
PostPosted: January 19th, 2015, 4:36
:mrgreen:
PostPosted: January 21st, 2015, 6:21
Spildit wrote:
day1data wrote:
hvd wrote:
Hello
good luck
Assuming that there is nothing wrong with your process of swapping the head stack and that the head stack is fully compatible, you will now need to adapt the patient ROM to the new head set adaptives using something like Pc3k or MRTLab tools. There is a video posted here on the forum on how to do so with MrtLab tools. The idea is to make the original ROM have the adatives os the donor heads. This is needed for F3 Arch seagates.
I didnt know that you need to change ROM when you change the HSA? So you say that every HSA is unique?
Users browsing this forum: No registered users and 73 guests
