 Post subject: WD2500AAJS strange case ?
PostPosted: October 21st, 2014, 11:45
Hello ,
customer claims that he just disconnected this drive to replace it with bigger capacity drive , after a while he tried to conect it again to get some data , and drive is not detected ..
drive is WD2500AAJS-08B4A0
it clicks couple times before register DRDY and DSC , nothing can be read after that .
entering kernel mode , will allow me to read only mod01 , then drive will spin down . heads map is 0.1
heads are OK ,
trying to read tracks , i will barely be able to read couples ..
any hints ?
althought the customer will not handle FW corruption recovery fees, but accepted to test on the drive ( data dont worth it )
thanks
 Post subject: Re: WD2500AAJS strange case ?
PostPosted: October 22nd, 2014, 4:22
If data don't worth it, why waste your time?
Anyways, have you tried to hotswap?
Does the drive spin down when it goes to DRD DSC?
PostPosted: October 22nd, 2014, 13:01
thanks for your reply , hot swap allowed data access .
PostPosted: October 22nd, 2014, 16:23
Good job Raven
PostPosted: October 23rd, 2014, 4:14
Great! :)
Users browsing this forum: Google [Bot] and 198 guests
