 Post subject: Head swap on Apple branded hard drive
PostPosted: October 6th, 2014, 13:32
Gurus,
I have an Apple branded WD5000AAKS-40V6A0 (Tahoe) hard drive with a failed head stack. Similar Apple hard drives on Ebay are going for around $300, which is much more than I am willing to spend. Normally for Royal WD drives I try and match model, including the XXV6AX portion, along with country, close date and part of the DCM (although I know there is ample evidence to suggest that none of this is absolutely critical or necessary).
My question is whether a non-Apple branded WD drive with a different XXV6AX would be just as good a donor. Obviously head map and adaptives would have to be a match, or close, as well.
Thanks in advance,
Shawn
 Post subject: Re: Head swap on Apple branded hard drive
PostPosted: October 6th, 2014, 13:59
Welcome to the world of data recovery. You may have to just charge more for the recovery.
PostPosted: October 6th, 2014, 14:07
Exactly...or get into the drive refurbishing business.
PostPosted: October 6th, 2014, 15:23
Yes is another way
PostPosted: October 6th, 2014, 15:43
Headstack matching for Western Digital:
http://www.alexsoft.org/viewtopic.php?t ... 4555#p4555
PostPosted: October 6th, 2014, 18:46
You don't need apple branded drive. That has more to do with firmware than anything hardware related. Finding one with a close DCM and date is more important.
Try this guide:
http://www.donordrives.com/hard-drive-pcb-donor-match
It's not as exhaustive as what fzabkar posted, but will get you a match 90% of the time.
PostPosted: October 6th, 2014, 20:01
DCM and date code aren't key parameters on this model.
http://www.datasaversllc.com
PostPosted: October 6th, 2014, 20:20
Thanks guys for the information and suggestions. I had to move fast, so I went ahead and ordered 2 drives for this recovery. Neither matches the XXV6AX parameter, but one is is Apple branded and both match fairly closely on other parameters. Hopefully adaptives are close and we get a hit. I will post back with the results after the swap.
Shawn
PostPosted: October 23rd, 2014, 21:57
Just wanted to share that the case was a complete success. For the record, here is the relevant information:
Patient:
26 Oct 2010
HHNNHTJMGN
Donor:
Apple branded WD5000AAKS-402AA0
13 Mar 2011
HHRNHTJAGN
Maybe this will help someone in the future.
Users browsing this forum: michael chiklis, ora and 177 guests
