 Post subject: very slow rescue WD5000LPVX
PostPosted: October 27th, 2014, 10:08
Hi all and thank you in advance for your suggestions and aid.
Some months ago my laptop dropped down on the floor when it is running. It doesn't starts anymore, so I open it and extract the HD (WD5000LPVX).
I used various tool in order to attempt rescuing some data. The most effective I found is gnu ddrescue.
DDrescue can copy the raw data, but the speed is very slow. The rate is between 27000 B/s and 45000 B/s. It takes 5-6 months for rescue the whole disk (500 GB).
I tried to change many ddrescue parameters and I tried to change hdparm flag and settings in the hope of increase the rate.
The rate remaining substantially the same. So I suppose that the problem is some aligning issue caused by the drop.
Someone can suggest some software, procedure or tips?
Thank you very much.
francesco
 Post subject: Re: very slow rescue WD5000LPVX
PostPosted: October 27th, 2014, 11:30
Send it to a professional data recovery lab that who will be able to safely diagnose and correct the point of failure.
PostPosted: October 27th, 2014, 14:46
francesco
if you kept using software on such hdd case (particulary dropped drives ) , i doubt that you will ever see your data again unless u r willing to pay extra $$$ is best scenarios ..
i am working on a similar case , where case was recoverable , and thanks to softwares and the owner faith in getting his data for free , now the case is unrecoverable ..
PostPosted: October 28th, 2014, 6:50
Thank you very much for yours advices.
HD content isn't very important data so I'm not interested in a professional rescue service.
Indeed I'm very curious about this field and I want try to rescue data as much as possible.
Until now I've rescued about 30Gb of not consecutive data.
I would like to try another strategy:
-reading the master file allocation table
-rescue only interesting file sector by sector
Is it possible? It is a feasible strategy.
Thank you for the support.
francesco
PostPosted: October 29th, 2014, 3:44
many tools do this:
r-studio
GetDataBack
dmde
but the more you read the drive the more damage it will do if there is any damage already in there ata all
PostPosted: October 30th, 2014, 11:03
Thank you very much HaQue!
I can see all files in the drive and I can rescue only needed files whit evaluation/demo version of dmde and r-studio (with some limitation).
It takes a while but I don't need to rescue the whole disk.
Are there some free tools similar to dmde and r-studio (preferably on Linux)?
Thank you again :-)
PostPosted: October 30th, 2014, 14:30
Here is a Windows tool for recovering files with bad blocks.
Bad Block Copy for Windows:
http://alter.org.ua/soft/win/bb_recover/
 Post subject: Linux data recovery software
PostPosted: October 30th, 2014, 17:43
If Linux OS is the point, then try UFS Explorer, three of its editions are available for Linux: http://www.ufsexplorer.com/download.php?prod=sr&os=lin
You can also fully test it in shareware mode and personal license e.g. for Standard Recovery is 40 Eur.
Users browsing this forum: No registered users and 215 guests
