 Post subject: Any of you knows QNAP TS-569L RAID5 parameters
PostPosted: October 30th, 2014, 12:16
Hi Guys, i have here 5 drives from QNAP TS-569L.
RAID5 level configured, 1 drive failed.
I am testing with ReclaiMe, but no raid parameters found.
Any of you know QNAP TS-569L RAID5 Parameters?
Thanks for your help
 Post subject: QNAP TS-569L NAS recovery
PostPosted: October 30th, 2014, 14:53
RAID 5 level configured, 1 drive failed.
Examine mdadm config. Although, according to my experience, it can also be damaged, so pay close attention to data/parity rotation on the drives.
P.S.
We'll be glad to help recovering this NAS remotely.
Let me know if you decide that assistance is necessary.
 Post subject: Re: Any of you knows QNAP TS-569L RAID5 parameters
PostPosted: October 31st, 2014, 7:06
Hi Dmitri!
I'LL try mdadm config file, is a good idea because i suppose Linux part is ok on all drives.
i'll report you about mdadm file info.
So many thanks,
ill report you to take a look remotetly
PostPosted: October 31st, 2014, 8:12
"mdadm --examine {partition}" is all you need to read the linux RAID meta data. Just replace {partition} to the each drive's specific partition details, such as /dev/sda1.
From the report, you should be able to determine the RAID type, drive order, last time drive was online and block size.
Good luck.
PostPosted: October 31st, 2014, 8:15
thanks Dmitri, Luke, i'll take a look this afternoon.
I'll report here
thanks
PostPosted: October 31st, 2014, 10:29
i taked a look to mdamd.conf file and not showed raid info.
take a look for config files.
config.rar [451 Bytes]
Downloaded 377 times
PostPosted: October 31st, 2014, 10:40
As I said, try to read the raid meta data from the drive partitions using mdadm in linux.
Users browsing this forum: Bing [Bot] and 90 guests
