 Post subject: Seagate head matching help.
PostPosted: November 19th, 2014, 19:02
So I have a couple drives that I'm looking for donors right now, and I'm not finding a perfect match. Either it's wrong site code, wrong first 3 of serial, wrong part number, or wrong FW.
So my question is, what's your order of priority that you find best for matching Seagate drives when it comes down to ?
I've generally gone with:
1. Date
2. Site
3. First 3 of serial
4. P/N
5. FW
As order of what's most important in that order. However now I'm faced with choosing between these two options
Drive 1:
FW: Same
P/N: Same
First 3 of serial: Same
Site: off
or
Drive 2:
P/N: Same
Site: Same
FW: Same
First 3 of Serial: Off
So which is more important First 3 of serial, or site code?
 Post subject: Re: Seagate head matching help.
PostPosted: November 19th, 2014, 19:32
It is not possible to match Seagate heads just by looking on labels.
PostPosted: November 20th, 2014, 5:46
both are important, For Site WU vs SU are ok sometimes.
Data Recovery Pakistan
PostPosted: November 20th, 2014, 7:49
yes some times in same model head map arrange is physically different
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: November 20th, 2014, 15:31
Of course I realize that there's no sure way to know. I'm just curious what others are using when shopping for drives trying to find a match.
PostPosted: November 21st, 2014, 2:01
Dear Doomer
Can you pls. educate us on most critical matching parameters for Seagate from your vast experience.
thank you
PostPosted: November 21st, 2014, 3:03
athena wrote:
Dear Doomer
thank you
As Doomer says, it's not possible to tell for sure from the label.
You need the drive in your hands :-)
