 Post subject: Looking for ROM and loader version 000500FA Pincilite
PostPosted: November 21st, 2014, 5:00
looking for ROM and loader for WD1600AAJS-75M0A0 version 000500FA Pincilite.
Least if one can help me with MOD11
Thanks for Support.
 Post subject: Re: Looking for ROM and loader version 000500FA Pincilite
PostPosted: November 21st, 2014, 6:24
Here's mod 11 from 250Gb version with ROM version 000500FA
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 170
>Zone allocation table................... : Ok
>SA SPT.................................. : 1311
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 05.FAE
>ROM generation.......................... : 05.FAE
>Link table version...................... : 04.0E.
>Consolidated ROM version................ : 000500FA
>ROM Modules:
>Flash ROM dir reading................... : Ok
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>ROM Firmware version.................... : 000500FA
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
Should do the trick :-)
11.rar [147.68 KiB]
Downloaded 351 times
PostPosted: November 21st, 2014, 6:49
Here are mods11 and 13 and ROM.
It's from a 250GB but it should work for you.
PostPosted: November 21st, 2014, 6:50
Ha, Sean beat me to it!
PostPosted: November 21st, 2014, 6:57
here is WD1600AAJS-75M0A0
and if you need full fw i will upload for you
11.rar [147.66 KiB]
Downloaded 320 times
http://www.hpwlab.com
PostPosted: November 21st, 2014, 16:41
Too slow!!
Must be the time difference between UK and Greece :-)
PostPosted: November 22nd, 2014, 0:01
Thank you so much all of you for your kind support
Its done.
Thanks again.
Users browsing this forum: WebClaw and 68 guests
