 Post subject: WD1200JB PCB Failure No ROM
PostPosted: November 22nd, 2014, 18:29
The above drive has a blown PCB. Big hole in the motor chip. The board has parallel flash so cannot swap ROM chip. I have a donor board which gives me access to SA, but not data due to the incorrect ROM. The original board does power up, but stays BSY. Is there anyway to get the original ROM from the SA? (don't think there is with this drive family). Guess my only option is to try to get the board to come RDY? Removing TVS chip does not work.
 Post subject: Re: WD1200JB PCB Failure No ROM
PostPosted: November 22nd, 2014, 19:03
Swap ROM (flash)...
http://www.rescue-it.se
PostPosted: November 22nd, 2014, 20:47
ROM is integral on the I chip. Not possible to do a chip swap.
PostPosted: November 22nd, 2014, 22:08
Flash rom is right in front of you. Pretty easy with adapter and reader. :shock:
PostPosted: November 22nd, 2014, 22:12
That was pretty funny! :mrgreen:
PostPosted: November 23rd, 2014, 1:24
U8 is it.
http://www.datasaversllc.com
PostPosted: November 23rd, 2014, 1:34
jono-ats wrote:
U8 is it.
:shock:
PostPosted: November 23rd, 2014, 4:48
ROM is on U2...
PostPosted: November 23rd, 2014, 6:38
M29F102BB...That's the rom chip you should move it to the working board.
Rgds
www.datasave.ro
PostPosted: November 23rd, 2014, 7:04
Tutorial - Linear and Switchmode Regulators used in HDDs:
http://www.alexsoft.org/viewtopic.php?f=59&t=231
Datasheets for HDD semiconductors, regulators, op-amps:
http://www.users.on.net/~fzabkar/HDD/HD ... _Regs.html
Datasheets for HDD memory ICs including EEPROM, EPROM, flash:
http://www.users.on.net/~fzabkar/HDD/HD ... Flash.html
PostPosted: November 23rd, 2014, 10:35
My error -- you're absolutely right.
Maybe I shouldn't post so late at night!
The ROM is U2.
PostPosted: November 24th, 2014, 16:56
The ROM is U2.
Thank you.
Users browsing this forum: No registered users and 98 guests
