 Post subject: Re: Seagate 7200.12 not recognized by BIOS, V40 and N1 fail
PostPosted: November 21st, 2014, 8:30
lcoughey wrote:
I agree with labtech, you must first deal with the physical before logical issues.
But the physical issues are LIKELY, not for sure. There is no strange noises, drive spins perfectly, there was (I hope) no physical shock, personally I don't see any physical symptoms. I take it easy, no pressure, data is important, but I must consider all yes's and no's for any solution.
northwind wrote:
That's a YES.
YES for m0... or YES for DR pro or YES for exhaustion aspect?
PostPosted: November 24th, 2014, 6:20
labtech wrote:
Hey, it took a lot of exhaustion to learn without tools or make money to buy the tools you have now, no?
northwind wrote:
That's a YES.
PostPosted: December 1st, 2014, 16:01
Hi:
In my experience, No HOST FIS-ReadyStatusFlags 0002A1A5 and N1 fail command is because there is not formatted user partition. After m0,2,2,,,,,22 command you will can do N1 command and ¨No HOST FIS-ReadyStatusFlags¨ error will not longer appear.
But this does not guarantes that drive will be recognize by bios. I´ve seems some cases like you and i think that the problems is some firmware module corrupted produced by bad sectors in the system area.
I think that the m0,2,2,,,,,22 does not affect data.
PostPosted: December 2nd, 2014, 7:18
Running m0,2,2,,,,,22 on a 7200.12 drive is NOT a good idea.
PostPosted: December 15th, 2014, 8:51
Don Oleg wrote:
Hi:
...But this does not guarantes that drive will be recognize by bios.
...I think that the m0,2,2,,,,,22 does not affect data.
Thank you for sharing your opinions, that's mean much.
Could you or anyone explain why it's not good please? Does it really affect the data? Is there any additional info/docs about what exactly that operation does.
Still undecided if should I risk with m0 or not. Any additional opinions are welcome.
PostPosted: December 15th, 2014, 11:00
m0,2, does not take into account the NRG list and you can end up with a lot of mess.
PostPosted: December 15th, 2014, 20:29
Quaz wrote:
Data is critical.
You're going to run a command you know nothing about on the critically important drive? Get another drive and experiment on it first.
Considering the question above, it doesn't look like you know how to reassemble the translator manually should you have it ruined during regeneration.
Users browsing this forum: No registered users and 118 guests
