Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: hgst laptop internal drive 500gb serious problems
PostPosted: November 23rd, 2014, 19:15
so i ll just wait till it dies nothing i can do?
PostPosted: November 23rd, 2014, 20:01
Zero-fill it, then scan it again. If you get the same result, then there isn't anything you can do.
PostPosted: November 23rd, 2014, 20:03
im right no doing low level format and after i ll see whats going on thanks,maybe later i ll try spinrite i heard good things abouth this program,is it something like hdd regenerator?
thanks
PostPosted: November 24th, 2014, 2:10
See viewtopic.php?f=1&t=28780
PostPosted: November 24th, 2014, 2:39
after low level format nothing changed.....
PostPosted: November 24th, 2014, 10:34
one more thing guys,the surface test as i showed you before says that i have slow sectors,
but i run the same test with hard disk sentinel and hd tune pro and they didnt find any problems.
is there any possibility that hddscan made a mistake?
also i made a low level format but health of the drive is still 99.
PostPosted: November 28th, 2014, 16:46
hello guys again,everybody here says to me that hard drive is dead and i did with 5 different programs surface tests and its perfect also i did scan 3 times with hdd regenerator and its cool and last thing i did is to maintaince the drive with spinrite which took 30 hours and this also didnt find problems.
Users browsing this forum: No registered users and 52 guests
