 Post subject: WD10TMVW-11ZSMS1
PostPosted: December 4th, 2014, 6:23
hi,
I got western usb hard drive. when I connect to pc via usb, usb is not detected but the drive spins up with 4 clicking noise then stop spinning. my question: is the problem with the board or the drive.
 Post subject: Re: WD10TMVW-11ZSMS1
PostPosted: December 4th, 2014, 6:44
Not a PCB problem, I think bad heads.
PostPosted: December 4th, 2014, 9:30
+1
PostPosted: December 4th, 2014, 10:18
For these drives, definitely heads.
PostPosted: December 4th, 2014, 14:04
Totally agree. Bad heads.
PostPosted: December 4th, 2014, 18:05
4 clicks=Searching servo because heads are down......
Spin down=Put drive itself safe mode.
PostPosted: December 8th, 2014, 0:20
and about usb not detected?
PostPosted: December 8th, 2014, 13:32
It can't identify the hard drive model since it fails to initialize. Thus the "usb not detected" error.
It's heads, not PCB. In fact, I don't think I've ever seen this model with a bad PCB. It's pretty much always heads.
PostPosted: December 9th, 2014, 6:32
thank you all.
Users browsing this forum: Bing [Bot] and 59 guests
