 Post subject: Seagate 1TB HDD showing just 3.88GB in disk manager
PostPosted: December 7th, 2014, 1:29
Hi my desktop HDD Seagate 1TB stopped working all of a sudden and and stopped booting.
so removed from desktop to connect to my external 1TB Hdd's usb pcb board and plugged through USB to my laptop.
In laptop's disk management it shows just 3.88GB (unallocated space)
can any one help me out to solve the issue so i can get full space back to be use and also to recover my data out of my Hdd.
also attaching the sound of the Hdd which it is making when powered on.
 Post subject: Re: Seagate 1TB HDD showing just 3.88GB in disk manager
PostPosted: December 7th, 2014, 1:31
:roll: :cry:
PostPosted: December 7th, 2014, 11:17
The free service here is lousy, eh? No answers 3 minutes after you originally posted. I'd take my business elsewhere.
PostPosted: December 7th, 2014, 11:37
Smilies after 3 min was posted to express my self what I am going through due to loss of data thats it.
Also I'm aware issue is due to corruption in firmware so also replaced the PCB it self of another HDD which matched same model, firmware & site code but still it made same sound n same result in disk management is what I got this is what confusing me what could be solution
PostPosted: December 7th, 2014, 12:00
Okay, thanks for the clarification. I took them as expressing contempt and exasperation and assumed it was because nobody had replied yet. I'll let others reply, as I don't have the knowledge and experience to be of any use here.
PostPosted: December 7th, 2014, 12:17
:-) thanks buddy...
PostPosted: December 7th, 2014, 12:33
Its also my mistake never introduced my self I am a DIY guy with automobiles n wit electrical stuffs
Working as desktop n server support
Have recovered few HDD n SD card from applications as they were detected but this is first HDD non detected
PostPosted: December 7th, 2014, 17:40
More than likely, something happened when you were working on the computer and it could have corrupted the NTFS partition table on the drive. It sounds like the drive is physically working fien, but its very early to tell. the important thing is not to Format the drive or write anything to it.
You will need to look for a recovery program to recover or fix the damaged partition table. The best thing would probably take the drive to a recovery company. It should be cheep as its a simple recover of data with no damaged drive, but its too early to tell.
PostPosted: December 8th, 2014, 3:21
Today morning used easeus recovery application even in that only one partition was showed of 3.88GB
and also in cmd mode used diskpart and guess what it remained the same 3.88GB
PostPosted: December 8th, 2014, 4:06
You didn't attach the sound file (or at least I can't see it on my iPad) so we can't tell if it's sounding healthy or not.
These drives behave like this if they have physical issues.
PostPosted: December 8th, 2014, 7:30
Agree with pcimage, showing 3.8GB capacity means the drive has some sort of internal problem and it's usually mechanical. But it could be something else too, so we need to hear the sound and if possible show us the terminal output of the drive on powerup.
PostPosted: December 8th, 2014, 7:53
Tried but not able to upload the sound file from mobile will give it a try once I reach home from system
And yes the last 4 connectors of power supply is been damaged will post that image too once I reach home
PostPosted: December 8th, 2014, 9:55
image of pcb connectors attached
tried to attach audio file but its not allowing to add wav. and mp3. format files to attach.
PostPosted: December 8th, 2014, 11:16
just now tried to connect again and a new tab of some warning was prompted by my DiskManager what does this means friends
PostPosted: December 8th, 2014, 13:40
It's a hardware issue, not software. Nothing you can do without special equipment will help, it will only make the situation worse.
Possibly the drive has a bad translator or something else wrong with it. You really should get it to a professional if the data is important.
PostPosted: December 8th, 2014, 14:49
Post a screenshot of the smart attributes here.
http://sourceforge.jp/projects/crystald ... rror=jaist
PostPosted: December 9th, 2014, 6:22
Your power connector is fine, otherwise the drive wouldn't spin up.
Compress your .wav file to .rar and upload .rar file here.
PostPosted: December 10th, 2014, 7:22
Thanks guys and yes it is reading meadia error (head is not working) so just need to swap the head from another hdd if just the model match is sufficient to select a donor hdd
head damage was informed by me senior who was earlier into HDD recovery course Traineer.
PostPosted: December 10th, 2014, 21:50
he opened it and saw the head damage? or guessed?
PostPosted: December 11th, 2014, 0:33
heard the noice making from hdd and told its head issue and its grinding the platter so dont use it often trying to recover with applications or you will loose the data, better change the swap the head from working one or hand it over to a proffetional to do that is what is said
Users browsing this forum: No registered users and 68 guests
