 Post subject: Pinnacle Loader WD3200AAJS-56B4A0
PostPosted: December 9th, 2014, 13:05
Hi
I need the loader for this drive:
WD3200AAJS-56B4A0
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 170
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 55.ASE
ROM generation.......................... : 55.ASE
Link table version...................... : 04.AD.
Consolidated ROM version................ : 005500AS
ROM Modules:
Flash ROM dir reading................... : Ok
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
ROM Firmware version.................... : 005500AS
ACELab partner
 Post subject: Re: Pinnacle Loader WD3200AAJS-56B4A0
PostPosted: December 9th, 2014, 13:24
good luck
11.rar [137.49 KiB]
Downloaded 496 times
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: December 9th, 2014, 14:56
Thank You Tawfeek,
ACELab partner
