 Post subject: Strange sound HDD ST2000LM003
PostPosted: December 9th, 2014, 7:29
I bought samsung/seagate ST2000LM003 and i have take the internal disc 2.5" 2TbB ST2000LM003 and put into the ps4. I heard that this disc make sometimes "beep" or "grr", is it normal?
 Post subject: Re: Strange sound HDD ST2000LM003
PostPosted: December 9th, 2014, 7:36
upload the sound file here, remember to compress the file before attaching
Data Recovery Pakistan
PostPosted: December 9th, 2014, 8:05
This is the sound.. sometimes it makes for three times, sometimes one times of 10 minutes, it is discontinuously.
HDD Sound.rar [142.47 KiB]
Downloaded 593 times
PostPosted: December 9th, 2014, 10:24
it could be, that Sony PS4 doesen't support your drive.
Research, if you can put any drive, or you need to do some modifications.
What kind of drive was in the PS4 before you put ST2000LM003 in
PostPosted: December 9th, 2014, 10:41
Do you heard the sound?
Before it was Hitachi, but ps4 support 12mm hdd 2.5".
Hitachi was 7mm, this is 9.5mm.. i don't think it's a compatible problem
PostPosted: December 9th, 2014, 18:03
Other opinions?
PostPosted: December 10th, 2014, 4:46
kekko95 wrote:
Other opinions?
Are you sure that sound is coming from the hard drive itself? Compatibility problems are common between hard drives and video game machines, it's not just that the drive meets physical requirements, sometimes is something as stupid as a matching file system, a matching serial number pattern, or an ATA password.
PostPosted: December 10th, 2014, 10:46
Maybe.. but i find this topic http://www.reddit.com/r/techsupport/comments/2kfx9r/
It's a common problem with this hard disk..
PostPosted: December 11th, 2014, 3:19
Hello kekko95,
to clarify, that problem is in hdd connect it to computer. If strange sound remain, then return it to shop to replace you with new one
PostPosted: December 11th, 2014, 8:28
It doesent work on pc because it's formatted for another system operation (ps4)...
PostPosted: December 11th, 2014, 17:08
Perform a full surface scan on the drive, then post the SMART report.
PostPosted: December 13th, 2014, 8:02
I already made it in past, before removing hdd from the case and it appeared without problem. There wasen't damaged part or something
Users browsing this forum: Google [Bot] and 222 guests
