 Post subject: WD Hard disk - write protected
PostPosted: December 11th, 2014, 23:42
Hi
WD 3.5" WD20EACS-11BHUB0 2TB Hard disk inside a WD external casing.
I managed to clone the hard disk.
But now when I try to scan I get the following errors for all sectors
Read disk WDMy Book 11301016 at position 46849536 failed after 1 attempts. The media is write protected (19)
Read disk WDMy Book 11301016 at position 46856704 failed after 1 attempts. The media is write protected (19)
The user did not set any password for the hard disk.
 Post subject: Re: WD Hard disk - write protected
PostPosted: December 12th, 2014, 6:34
Are you scanning using the USB bridge, or using the drive alone directly connected via SATA?
PostPosted: December 12th, 2014, 9:41
1. How did you clone the hard drive?
2. What model is the destination drive?
3. If you are using the USB bridge, are you sure it is functioning?
PostPosted: December 13th, 2014, 15:17
jag17 wrote:
Read disk WDMy Book 11301016 ..
PostPosted: December 14th, 2014, 6:44
I am using USB bridge.
When I scan directly using SATA, I see the following in R-studio after the r-studio scan complete
PostPosted: December 14th, 2014, 6:48
++ I used MRT Pro (http://en.mrtlab.com/)
++ Toshiba 4TB MD04ACA400
++ I am not sure whether USB bridge is still good or not
PostPosted: December 15th, 2014, 8:22
Is this hard disk hardware encrypted using USB bridge?
Do we need a working USB bridge to recover the data ? or can we recover the data directly from SATA connection?
PostPosted: December 15th, 2014, 12:12
Use MRT Pro to change the LBA of the destination drive to match the LBA of the original drive (as shown when the drive is directly connected, not as it shows through the USB bridge).
There's an encryption key sector near the end of the drive, but if the LBA is different the bridge won't look in the right place and it will show as "Write Protected" because it can't decrypt the data.
And yes, you need to use the bridge to decrypt in most cases. Though occasionally we do find some that aren't encrypted.
Hope this helps.
PostPosted: December 16th, 2014, 2:23
Hope this helps.
Thank you, I will try and update you
PostPosted: December 16th, 2014, 6:12
OP could have removed the drive from the case without mentioning it.
You must use HPA to cut down destination size to match the source.
Also, we've seen trouble with destination drives when they're not WD. If you can source a 2TB WD that would be better.
Users browsing this forum: No registered users and 58 guests
