 Post subject: Toshiba MK7559GSXF not detected + makes mechanical noise
PostPosted: January 7th, 2015, 0:05
The drive is spinning. No detection as a hard drive. Deep Spar can't see it either. No damage on platters.
Any thoughts if this is bad PCB board, or is it heads gone bad?
Thanks,
 Post subject: Re: Toshiba MK7559GSXF not detected + makes mechanical noise
PostPosted: January 7th, 2015, 3:06
99% certainly bad heads.
PostPosted: January 7th, 2015, 8:05
If drives spins and there are not any strange noises, then it could be a PCB issue (but can't be excluded other problems as bad sectors or bad heads).
I had a case few weeks ago about a Toshiba drive which wasn't detect anymore but it was spinning good, i solved the case by swapping the PCB and the ROM.
viewtopic.php?f=1&t=28898
My firmware database:
PostPosted: January 7th, 2015, 10:37
I think basically can be everything.
You need to be able to fully test the drive components in order to be sure about it.
PostPosted: January 7th, 2015, 11:08
Could be:
1. Damaged heads
2. Media damage
3. CP/GList damage
4. Some or all of the above
PostPosted: January 7th, 2015, 15:51
From title.... "+ makes mechanical noise".
From that, I'm assuming untoward noises.
PostPosted: January 7th, 2015, 15:55
Sometimes i don't even read titles, i just go directly inside the thread :lol:
If there are mechanical noises then most likely heads are damaged.
PostPosted: January 7th, 2015, 16:08
Hope you did not open the drive to look inside...
Users browsing this forum: No registered users and 63 guests
