 Post subject: Lexar Professional CF Card - Opening the Case
PostPosted: January 8th, 2015, 15:49
What is the best technique for opening these cards? I have purchased two used ones so I can experiment before attacking the clients card. One word of advice was "cut plastic corners/edges and then remove metal coating". Any other techniques? ie Dremel?
 Post subject: Re: Lexar Professional CF Card - Opening the Case
PostPosted: January 8th, 2015, 16:32
Dremel not required!
I usually lever a blade under the metal covers, near the pin connections first, and then prise off the covers. Careful, as there are little clips going into the plastic frame.
Then it's easy to wrestle the CF card out of its plastic frame.
As you say, better to practice on an unimportant card first.
PostPosted: January 8th, 2015, 16:52
With CF Cards, as with all flash recoveries, you mostly assume you wont be putting them back together for normal use. So go carefully - I do as Sean says and never force or bend very much. Some of the PCBs are very thin.
As an extra tip:
I buy many many 5-bay plastic cases, the kind you would put fishing lures or sewing supplies in, and give every device a catalogue number. I write in a .xlsx what the flash chips are, what the controller chip is and what steps and data used to recover it.
The single most important thing in Flash recoveries is knowing what how a same/similar device you have was recovered.
Once you start getting a feel for the peculiar traits of different devices you start to make progress. but never assume anything, sometimes you see strange stuff such as one controller using another's Wear Levelling, or chips that are either fake or just plain odd-ball.
PostPosted: January 8th, 2015, 17:19
Indeed I have already scared myself once almost mixing up two clients chips. I learned a quick lesson that this is very different to HDD's and just logging serial number etc. Organization is key. I now have small, sealable plastic boxes to store each clients flash drive, only one is ever open at a time.
and give every device a catalogue number. I write in a .xlsx what the flash chips are, what the controller chip is and what steps and data used to recover it. The single most important thing in Flash recoveries is knowing what how a same/similar device you have was recovered. Once you start getting a feel for the peculiar traits of different devices you start to make progress. but never assume anything, sometimes you see strange stuff such as one controller using another's Wear Levelling, or chips that are either fake or just plain odd-ball.
A lot to learn I think....but thats half the fun. Many thanks.
PostPosted: January 8th, 2015, 17:34
I use a metallic sharpie to write the job number (and chip number 1,2,3,4..) on each of the NAND chips. And black sharpie to write the job number and chip number positions on the PCB of each device.
Then keep each job in its own little plastic box.
PostPosted: January 8th, 2015, 17:39
pcimage wrote:
I use a metallic sharpie to write the job number (and chip number 1,2,3,4..) on each of the NAND chips. And black sharpie to write the job number and chip number positions on the PCB of each device. Then keep each job in its own little plastic box.
A metallic sharpie is my next purchase, bit cheaper than the microscope.... :wink:
PostPosted: January 8th, 2015, 18:42
Yes I use Artline 990XF metallic gold marker and a silver sharpie.. have to hide them from the Daughter!
PostPosted: January 9th, 2015, 5:09
I either use Sean's method, but first I will try and split the CF. They are usually made in two parts (top and bottom) by putting a large bladed screwdriver in the location key slot and twisting it will usually start the separation. They they can be clipped or glued back together when you are done.
https://www.mjm.co.uk/
PostPosted: January 12th, 2015, 15:53
I use a little hot air to heat the metal and the blade, it comes apart cleanly
Recover My Flash Drive
PostPosted: January 12th, 2015, 16:34
I'm not familiar with that specific card, I know some are just glued and the heat/exact-o-knife trick works well. Others though are actually clipped in and you may have to cut the outer plastic just to be safe.
PostPosted: January 12th, 2015, 16:48
Thanks everyone. With this particular CF card the x-acto knife under the corners of the metal covers work great to get it started. It was glued so will use heat in the future, but just sliding the tip of the knife around the plastic case released the glue without an issue. Once again, thanks.
Users browsing this forum: Ahmed Saeed and 101 guests
