 Post subject: Terminal output on power on
PostPosted: January 9th, 2015, 8:48
Hi
I have a Seagate Barracuda 7200.7 120GB and I get the following message through terminal when it powers on. Any suggestions? It only started happening when I ran a selfscan via terminal and then stopped the selfscan as it was taking forever. Cheers
Interface task reset
4096k x 16 buffer detected
PUMA - 1_Disk 0.07 09-26-04 14:00
Head Mask FFFF - Switch to full int.
Spin Ready
3.42 09-26-04 14:03
(P)(H)SATA Reset
OVERLAY FAILED(
T>
 Post subject: Re: Terminal output on power on
PostPosted: January 9th, 2015, 10:12
Thanks but I'm using this as a learning curve so I'm going to try and do it. Thanks for the first post though I'm re-running the selfscan as suggested and will let it complete.
Will the ATA overlay and VENDOR get re-written at the end of the self test?
http://www.computerworksuk.com
PostPosted: January 9th, 2015, 10:18
OK. I ran the self test and let it complete and the error has gone. I now am getting "Not Interface Age!".
Can you advise? Thanks for your help by the way!
Spin Ready
3.42 09-26-04 14:03
(P)(H)SATA Reset
Not Interface Age!
VALID Cert Disk Code Detected - Revision # .082
Cert Table loaded
T>
PostPosted: February 3rd, 2015, 12:13
Thanks. What if I didn't back up the ATA track to begin with? Do I need to source the firmware from another identical drive?
PostPosted: February 3rd, 2015, 14:36
Ok thanks for that
PostPosted: February 4th, 2015, 2:24
Spin Ready
8.01 04-05-04 15:38
(P)PATA Reset
Master
T>
T>/1 access mode 1
1>N1 clear smart
Initializing SMART Sectors...................................
1>
1>/
T>(( VALID Cert Disk Code Detected - Revision # .248
T>i4,1,22 clear glist
T>/2 access mode 2
2>p6
Score= : #
Measured spin speed: 406 ticks per rev (48 ticks per millisecond)
EndLBA,Pred,Act,%Deg,Score
Pgm=00 Trk=000AD(000AD).1(0).3E8(375) Zn=0 Err=00 ErCt=0000 Hlth=0008 CHlth=0000 Ready LBA=00050A0F
Pgm=00 Trk=00111(00111).0(0).1B8(3C5) Zn=0 Err=00 ErCt=0000 Hlth=0008 CHlth=0000 Ready LBA=000838D8
Pgm=00 Trk=00142(00142).0(1).447(1C7) Zn=0 Err=00 ErCt=0000 Hlth=0008 CHlth=0000 Ready LBA=0009CEC8
PostPosted: February 4th, 2015, 4:21
Am I don't follow Galaxy haven't you posted this?
Users browsing this forum: No registered users and 100 guests
