 Post subject: Is This The Read Channel?
PostPosted: January 15th, 2015, 13:37
I have tried testing this board to define the read channel but the tests are inconclusive. I have marked what I presume is the read channel, can anyone confirm?
ST31500541AS
Board 100535537 REV A
 Post subject: Re: Is This The Read Channel?
PostPosted: January 15th, 2015, 14:34
Looks right to me...or the two just down to the left in the photo.
PostPosted: January 15th, 2015, 14:46
Its deciding which one of those two sets I am having issues with :D
PostPosted: January 15th, 2015, 16:27
I think you have the right two highlighted, the other set looks like it goes to the preamp which wouldn't make much sense.
PostPosted: January 15th, 2015, 16:42
you got it right mate
I've had same one a few weeks ago and I used the same pins
PostPosted: January 15th, 2015, 16:50
Thanks everyone :D
PostPosted: January 15th, 2015, 17:10
My tutorial shows you how to distinguish between the read and write pairs with a simple voltage measurement.
How to identify the Read Channel when no terminators:
http://www.alexsoft.org/viewtopic.php?f=24&t=123&p=1632
PostPosted: January 15th, 2015, 19:37
That is always my go to link to test these boards. But for some reason I was getting no voltage at all from the channels. I have another board I will test/compare it against tomorrow.
PostPosted: January 16th, 2015, 17:32
Why not? Where do they go, then, if not to the preamp?
