 Post subject: platters spin, heads arm dosn't move from park to platter
PostPosted: January 21st, 2015, 3:24
I have a WD1600AAJS-75M0A0 that I changed the heads.
Now the I can see the platters spin but the head arm doesn't move from park to the platters. When I re-use the new heads in the donor drive, it works fine.
The donor have the same 4-to-7 DCM, same country, same model, and 6 months between the manufacture date of the 2 drives
Could the manufacture date be the problem? why the new heads doesn't even clicks. it doesn't move from park?
Regards,
 Post subject: Re: platters spin, heads arm dosn't move from park to platte
PostPosted: January 21st, 2015, 3:29
can you post the ROM of the both patient and donor here ?
Data Recovery Pakistan
PostPosted: January 23rd, 2015, 4:50
what's about microcode between Donor and patient Rom
if there are different enough in microcode drive will not spin
http://www.hpwlab.com
Users browsing this forum: Google [Bot], jimmydata and 54 guests
