 Post subject: iMAC Question
PostPosted: January 22nd, 2015, 11:51
Dear reparing experts,
i started having this stupid BLACK line in my lovely iMAC 27"
and tried to send it to some tech. to see whats going on
they all said, its the Screen which needed to change
is that correct?
thank you
 Post subject: Re: iMAC Question
PostPosted: January 22nd, 2015, 12:27
Yeah, almost sure.
On laptops, when such a case appear 90% of the times is the panel.
On a 27" it will not be cheap.
ACELab partner
PostPosted: January 22nd, 2015, 12:30
pclab wrote:
Yeah, almost sure.
Thnx for the quick reply my dear,
but how expensive is it more or less?
thx
PostPosted: January 22nd, 2015, 14:41
We provide Apple service too. So I can confirm that it is screen failure. And yes, it will be quite expensive.
PostPosted: January 22nd, 2015, 15:28
Here is a used LCD panel for AU$175:
http://www.ebay.com.au/itm/Genuine-Appl ... 1116914621
It appears that crApple was hit with a class action over faulty 27in LG-LED-backlit displays in 2013:
https://gigaom.com/2013/10/29/apple-hit ... c-screens/
PostPosted: January 22nd, 2015, 15:38
Send to Frank...shouldn't be more than a $15 fix.
PostPosted: January 22nd, 2015, 15:50
Any board jockey with a screwdriver shouldn't have a problem replacing a panel. There are plenty of guides on the Internet if you can't work it out for yourself.
PostPosted: January 23rd, 2015, 8:08
@fzabkar
Thank you for the links - seems am not the only one suffering from this defect.
and i tried to send it to iMAC repairing tech. and he told me that screen must be changed,
saw some posts & video`s of same problem, but am thinking should i:
change it? or use Thunderbolt adapter and use another screen
feel bad about Apple really, my older iMAC is I3 and this is I7
and never had problems with the old only the damn new
thank you guys again for the tips.
PostPosted: January 23rd, 2015, 10:40
Not in warranty?
I would change it. or sell it with fault and buy a new one. Personally I don't like Mac, but if you are going to pay for the nice looking kit, you need to have nice looking kit.
As Franc said, it doesn't have to be expensive, and changing screens isn't too bad.
I guess it is a personal preference if you use a thunderbolt and screen or change it. If you put a 30" in front you wont even se it back there :)
PostPosted: January 23rd, 2015, 12:53
HaQue wrote:
Not in warranty?
I cannot work with small screens (Age problems)
and most probably will order one soon
thank you
PostPosted: January 26th, 2015, 12:05
Problem solved with thunderbolt
will use it this way better, not worth spending more.
thank you guys :>
PostPosted: January 26th, 2015, 12:26
Can definitely tell how much better the screen is on the Mac
PostPosted: January 27th, 2015, 3:43
@ labtech
Well, am not going to use it in Graphix, just need speed + Mem & the most important thing is multiple windows in High resolution
nothing more.
and i dont use it much btw, only in special cases thats why not worth spending on it.
PostPosted: January 27th, 2015, 15:51
Gotcha... just saying Mac view is nicer from the contrast between one another in your quality pic.
