 Post subject: WD3200BEVT not detected.
PostPosted: January 23rd, 2015, 12:20
I have a a hard drive WD3200BEVT. It was working fine in a laptop when suddenly it crashed, and the laptop restarted. Since that moment, the hard drive is not even detected by the BIOS. I tried with another HD and the BIOS detect it and works fine. So I discard any BIOS or main board problem of the laptop.
I tried also to plug it in a external hard drive box to a USB port and seems that it spins but it's not detected neither by Windows.
Is there any chance to repair it? or at least to recover the data?
I read something about the firmware of the HD could be corrupted.
Thanks for help!
 Post subject: Re: WD3200BEVT not detected.
PostPosted: January 23rd, 2015, 12:36
The majority of times, laptop hard drives fail because of physical damage. If you value your data at all, you should have it assessed at a professional data recovery lab before further damage is caused.
PostPosted: January 23rd, 2015, 13:38
is there any strange sound like tik tik
is your hdd spin up and continue
or just spin up then spin down?
if you have no idea about HDD repair
i can help you online by Team viewer
http://www.hpwlab.com
PostPosted: January 24th, 2015, 8:37
+1
Data Recovery Pakistan
PostPosted: January 24th, 2015, 13:00
Hello
You need a proper diagnosis with DR tool to really know the problem of the drive.
Tell us from where you are then we can tell you someone close your place.
Récupération de Données
Users browsing this forum: Bing [Bot] and 60 guests
