 Post subject: WDC ROM MODEL-MAMMOTH—
PostPosted: January 3rd, 2015, 14:59
I have WD800JD-00HKA0 its detected as WDC ROM MODEL-MAMMOTH— and serial no: WDC-ROMSN#XYZ.
Pls any advice to fix this problem?
 Post subject: Re: WDC ROM MODEL-MAMMOTH—
PostPosted: January 5th, 2015, 8:57
Could be many issues. What is the drive's behavior?
PostPosted: January 5th, 2015, 10:42
1. Not original PCB
2. Damaged PCB
3. Damaged heads
4. Damaged SA
5. A combination of the above
PostPosted: January 5th, 2015, 12:43
Hi ,
What All Tools Do You Have At your Disposal Boss
PostPosted: January 5th, 2015, 23:41
Hi ,
Thank you to all.
Head test is ok .
Tool i used is Salvationdata hdd doctor
PostPosted: January 6th, 2015, 10:22
If PCB is native, then it may be a firmware problem. Try to access SA and see where the issue is.
PostPosted: January 29th, 2015, 2:41
You only need auto repair mod 11, 31, 02.
If it does not work you will rewrite for its three mod.
PostPosted: January 29th, 2015, 4:41
You will need a same model HDD.working firmware.hot swap ..stop motor...change donor PCB to patient hdd(PCB removed).....load 11..... power off...on....and if its a 11 mod issue corrected you get data.If its changed PCB or bad sec in firmware or bad 11... you will be unsuccessful.also other causes should be ruled out.
Salvation has this solution on its forum.
Users browsing this forum: No registered users and 45 guests
