 Post subject: 7200.9 BUSY
PostPosted: February 3rd, 2015, 15:39
The case with BUSY Status.
Tried to load APP, didn't work. (based on UNABLE to LOAD OVERLAY message)
Glist cleared, N1 didn't work.
Did CE Log Repair - worked. Started image. suddenly lost readyness, again BUSY.
T4E test:
Interface task reset
1024k x 16 SDRAM
TLITE - 1_Disk S-6B 03-22-06 10:53
Head Mask FFFF - Switch to full int.
Spin Ready
(P)SATA Reset
Not Interface Age!
VALID Cert Disk Code Detected - Revision # .09M
DiskAccess ReadSector EC=43 at ffffffff.00.0000
Cert Table loaded
T>T4E
T4E
Begin Test 4E
ASCII logging on
Wrong data format. Write Adaptives rejected
Not Power Cycling
ASCII logging off
ASCII logging on
R 2 sectors at CHS (16295,0,0) to/from 3e6
Disc Operation failed
Directory Entry File could not be paged into buffer! (page 0)
^Z
(ASCII logging off
T>^C
3.AAE 09-29-06_15:01 AAE,KL_1D_1H_S,3A
T>
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: 7200.9 BUSY
PostPosted: February 4th, 2015, 1:55
The first msg was "unable to loaf overlay". I tried to load app n Ata together. Didn't work!
The drive I fixed and started imaging from the middle. After imaging 20000000+ , it lost readyness. And then always busy...
From then the msg !
__________
THANK YOU
SHAHI
PostPosted: February 4th, 2015, 2:22
Spin Ready
8.01 04-05-04 15:38
(P)PATA Reset
Master
T>
T>/1 access mode 1
1>N1 clear smart
Initializing SMART Sectors...................................
1>
1>/
T>(( VALID Cert Disk Code Detected - Revision # .248
T>i4,1,22 clear glist
T>/2 access mode 2
2>p6
Score= : #
Measured spin speed: 406 ticks per rev (48 ticks per millisecond)
EndLBA,Pred,Act,%Deg,Score
Pgm=00 Trk=000AD(000AD).1(0).3E8(375) Zn=0 Err=00 ErCt=0000 Hlth=0008 CHlth=0000 Ready LBA=00050A0F
Pgm=00 Trk=00111(00111).0(0).1B8(3C5) Zn=0 Err=00 ErCt=0000 Hlth=0008 CHlth=0000 Ready LBA=000838D8
Pgm=00 Trk=00142(00142).0(1).447(1C7) Zn=0 Err=00 ErCt=0000 Hlth=0008 CHlth=0000 Ready LBA=0009CEC8
Try this
PostPosted: February 4th, 2015, 5:38
T>;
Age=60 Type=00 MxCyl=00000 MxHd=0 MxSct=000 BSz=002M TCode=00000000 ThermFlts=0000
T>N50,,22
N50,,22
Code - FD Track FFFFF(16201).0.1C0 Sns FFF Rty F7FF.58.80FF Rtf 1800 LBA 00000446
T>;
Age=50 Type=00 MxCyl=00000 MxHd=0 MxSct=000 BSz=002M TCode=00000000 ThermFlts=0000
T>
__________
THANK YOU
SHAHI
Users browsing this forum: No registered users and 225 guests
