 Post subject: WD3200BEVT module checksum error
PostPosted: February 11th, 2015, 21:19
Hello.
This hdd recognized well.
but can't access any data.
because, Translator module has CS error.
i tried Translator regenerate, but faild.
P-List module has CS error, too.
how can i recover this case?
thanks!
 Post subject: Re: WD3200BEVT module checksum error
PostPosted: February 12th, 2015, 3:27
Gotta read the book more...
Check each copy. Then attempt to resolve checksum issue.
Can do this from resource view and edit.
PostPosted: February 12th, 2015, 4:00
+1
Data Recovery Pakistan
PostPosted: February 12th, 2015, 8:34
Try to read each copy with "view and edit Resources" and tick in "Ignore Reading errors"....then you might combine them.
Bosse
http://www.rescue-it.se
PostPosted: February 12th, 2015, 15:59
Spildit wrote:
Alternative way if you can't read any copy of p-list and translator is to assure that you can write to p-list and translator and if not you change the modules place on dir. When you can write - no sa bad sectors you re-create p-list from self scan log and regen translator.
Is there an option to re-create plist from self scan log on pc3k?
PostPosted: February 12th, 2015, 17:57
Clever 2 ways.
Thanks labtech and Spildit
Users browsing this forum: No registered users and 47 guests
cron
