 Post subject: ST31000524AS and FW JC4B- Firmware upgrade reqd
PostPosted: January 23rd, 2015, 22:25
Friends,
I have one ST31000524AS and FW JC4B which recently have developed some complication.
Though it is detected, it disappears after 3 minutes and on sunsequent reboot it is detected.
I hope if i can upgrade with FW then the problem can be solved.
But unable to find suitable FW for upgradation. Someone please help to find out.
 Post subject: Re: ST31000524AS and FW JC4B- Firmware upgrade reqd
PostPosted: January 25th, 2015, 9:32
Seems like drive has FW issue. I advise you to try to connect terminal and find out problem.
PostPosted: January 27th, 2015, 11:57
Terminal non-operational. Donot know the short pins of this pcb. Some one please help in finding out.
Thanx in advance.
PostPosted: February 14th, 2015, 16:14
You can operate terminal.
After power the disk you could hit ctrl z.
After or before you could,nt do.
And no need to isolate motor with paper..
PostPosted: February 15th, 2015, 6:58
Hi, Is this drive from a Dell computer? JC49 is here:
http://www.dell.com/support/home/us/en/ ... erId=NJKYF
As always, FW Update at your own risk.
Bosse
http://www.rescue-it.se
PostPosted: February 15th, 2015, 13:07
Firstly, I would check it for media issues with something like MHDD or HDDSCAN (both downloadable from this forum).
I suspect it has bad sectors rather than a FW problem.
Users browsing this forum: Google [Bot] and 197 guests
