 Post subject: Seagate Business Storage 4-Bay NAS SRN04D Configuration
PostPosted: February 13th, 2015, 11:48
Had this RAID 5 in a couple of days ago. R-Studio would not detect the RAID configuration, but it built fine in UFS Explorer. So why my question? I want to learn more about this configuration not just accept that it built in UFS. I would like to study the RAID Ext file system. I know that R-Studio gives the parent and child relative sectors when looking at the RAID in Hex (which UFS doesn't) so I want to build it in R-Studio to help me piece together how the file system works and reverse engineers it. Anyone know the default?
 Post subject: Re: Seagate Business Storage 4-Bay NAS SRN04D Configuration
PostPosted: February 14th, 2015, 7:54
UFS gives that too .
If you want to repeat configuration, press raid edit in UFS auto-constracted array , you will see layot , order, stripe size. Repeat it in R-Studio.
Angel Data Recovery
PostPosted: February 16th, 2015, 14:03
DR-Kiev wrote:
UFS gives that too. If you want to repeat configuration, press raid edit in UFS auto-constracted array , you will see layot , order, stripe size. Repeat it in R-Studio.
I did see that thanks. I tried the parameters in R-Studio but it still does not build. However UFS does not give the offset which may be the issue.
 Post subject: Seagate Business Storage 4-Bay NAS recovery (SRN04D)
PostPosted: February 18th, 2015, 4:16
UFS Explorer shows everything except parent sector.
Offset is there, please check carefully.
 Post subject: Re: Seagate Business Storage 4-Bay NAS recovery (SRN04D)
PostPosted: February 18th, 2015, 13:16
Hey Dimitri. UFS does give the first sector of the RAID, but I presume there could be different offsets for different drives as using the first sector as the offset still doesn't build it. Could be PEBCAK of course :-)
Users browsing this forum: Google [Bot] and 256 guests
