 Post subject: western digital hard drive spins but does not work
PostPosted: February 2nd, 2015, 0:16
Hi guys,
I have got a WD hd (wdbabv5000abk) which is kinda old.
The problem is that I hear the hd spins but it does not work while it is connected to my pc.
Note: previously I was able to hold the usb cable in a certain direction and have the hd works. but it does not work anymore.
QS: is there anyway I connect the hd via a SATA cable (I see some pin near the usb socket but I do not know what it is)
appreciate your help
 Post subject: Re: western digital hard drive spins but does not work
PostPosted: February 2nd, 2015, 0:25
If the USB port is built right on the drive (Passport models & newer Elements models) the only way to get a SATA connection is to set up a new PCB board from a compatable SATA model and transfer the ROM chip. (U12). The pins can only gain Terminal access which won't be much use for recovering data.
This thread has the numbers to match between USB and SATA boards: http://www.data-medics.com/forum/viewtopic.php?f=5&t=13
However you should know that the data is almost certainly encrypted so it may not do any good unless you have a tool like PC-3000 that can decrypt it.
Your best bet may be to seek professional data recovery.
PostPosted: February 2nd, 2015, 5:18
If I'm not mistaken, WDBABV5000ABK is an Elements drive, therefore it shouldn't be encrypted. But I could be wrong. I have seen this model on older Elements SE drives, which didn't have the USB bridge embedded on the PCB. They were SATA drives with USB adaptor in their case. USB 2.0 drives.
OP can clarify.
PostPosted: February 3rd, 2015, 6:43
Looks like its the USB port thats causing the problem from what you have said. Just take the drive out of the case and take it to a electric repair shop and have the re-solder the USB connection. It should work again if there is nothing else wrong with it. That job should be very cheep... or you can do it yourself if you have soldering skills.
Shane
PostPosted: February 17th, 2015, 21:22
I found today that the original model number is "WD5000BMVV"
I am not still sure that whether there are any connector to SATA for the 12 pins near the usb cable or not.
any idea how to fix the usb port myself?
thanks again for your kind help guys. you rock
File comment: seems the usb port does not work, since the hdd spins
PostPosted: February 18th, 2015, 11:45
There is a slight possibility your USB connection might have some issues, but not likely.
You have to find compatible SATA board for your drive, modify it, image the drive and then decrypt it. Those drives could be very painful, if there is some other issues involved besides connection.
Good luck.
www.datarecoveryne.com
PostPosted: February 19th, 2015, 21:05
Any idea about how to modify it? I guess it would be hard to do it for me who has not ever done any professional soldering...
any easier solution? (other than taking to a specialist :)) )
PostPosted: April 10th, 2015, 18:09
Good luck.
Any easier suggestion?
Thanks in advance
PostPosted: April 10th, 2015, 18:40
In the unlikely event that you have a PCB fault, find a PCB supplier who will transfer the "ROM" (aka "BIOS") for you:
http://www.hdd-parts.com/13032620.html
PostPosted: April 14th, 2015, 14:39
I would say that replacing PCB with the ROM on this case is a GOOD BET because of this :
I think that there is a good chance that the USB connector is broken.
Unfortunately, that board does not match mine. (since it seems board number should exactly match)
lets see if I can find any specialist in Houston
Users browsing this forum: SWM and 192 guests
