 Post subject: Bad sectors (C5, C6 SMART values)
PostPosted: February 27th, 2015, 19:14
Hello!
I have an old IBM Thinkpad laptop with a 40 GB PATA HDD which shows SMART values C5: 65052 and C6: 4. It's been like that for a long time, about 2 years - the laptop is used daily and works perfectly.
My friend has a desktop with 1 TB HDD which was giving him problem, he couldn't boot into Windows etc., then he could again after running chkdsk etc. His SMART data shows only C6: 4.
So is there some rule why one HDD would be working fine and the other not even though it shows the same SATA value of C6? Should he replace the HDD?
Thanx!
 Post subject: Re: Bad sectors (C5, C6 SMART values)
PostPosted: February 28th, 2015, 5:06
can you upload the full s.m.a.r.t status of the drive here so some can point you to the right direction.
Data Recovery Pakistan
PostPosted: February 28th, 2015, 10:51
PostPosted: February 28th, 2015, 11:53
Maybe this will help.
http://www.z-a-recovery.com/manual/smart.aspx
ACELab partner
PostPosted: February 28th, 2015, 15:12
Thanx but it doesn't really tell me why one HDD works fine despite the corrupted secotrs and the other one doesn't.
PostPosted: February 28th, 2015, 16:07
Probably not only checking SMART can give you the answer.
Have you done a surface scan?
ACELab partner
PostPosted: February 28th, 2015, 17:18
No, I haven't. Which program would you recommend for the surface scan?
PostPosted: March 1st, 2015, 19:51
OK, I have used the MHDD before. What about the HDDScan (freeware)? Or the Windows' built-in ScanDisk (chkdsk)? Are those OK?
PostPosted: March 3rd, 2015, 19:17
HDDScan, Vitoria... That will work too.
ACELab partner
Users browsing this forum: Google [Bot] and 169 guests
