 Post subject: Restore SB2OC70P firmware into a Hitachi disk
PostPosted: March 1st, 2015, 9:14
Hi
I have just received a Samsung M3 1TB that looks like a Samsung (even the package and instructions) but is a fake. Istead of Samsung, the case holds a used (8000 hours) HTS541680J9SA00 Hitachi 80GB drive with a tweaked firmware that makes the unit report 981GB.
When the SO tries to write beyond 80GB the drive fails and stops responding. So it is unusable.
I will have my money back, no problem with that, but now I would like to fix that HDD firmware so I can use it.
Right now it has the SB2OC70P firmware. I will need a flashing tool for hitachi and the original firmware.
Does anybody know if this can be found anyware in the net??
Thanks in advance.
 Post subject: Re: Restore SB2OC70P firmware into a Hitachi disk
PostPosted: March 1st, 2015, 10:21
Your first step is to call or email hitachi support and ask for firmware for HTS541680J9SA00. Firmware file comes with the flashing tool.
PostPosted: March 2nd, 2015, 14:10
I have just sent them an email thought this URL http://www.hgst.com/support/create-case
Let's see if they reply properly.
Thank you!
PostPosted: March 21st, 2015, 14:40
I got no reply from them but I could use the hitachi FTOOL to set max LBA addressable sectors to 156301488 (that is the total number of sectors according to the manual).
Thank you!!
Users browsing this forum: Google [Bot] and 184 guests
