 Post subject: 7200.12 FW PROBLEM?
PostPosted: February 19th, 2015, 7:53
Hi guys,
I have a ST3500413AS 7200.12 that when i turn on in PC3K became ready but can't read the parameters.
When i connect with the terminal inside the family 7200.12 i have this log:
Rst: 0x10M
RW: Disc Ctlr Initialization Completed.
(P) SATA Reset
And when i try to read the ID the drive became very slow in the process but it can read the Model, Serial number, FW version and capacity.
I have access to sector 0 but can´t backup the modules the table dont show any modules.
I try to create a task but gives Drive ID error.. then the drive stops to be ready and became with DRQ to.
Does any one have this experience our have some case like this?
Appreciate any help, thanks in advance.
Data Recovery Technician - If Data is important don't DIY without knowing the real problem.
 Post subject: Re: 7200.12 FW PROBLEM?
PostPosted: February 19th, 2015, 10:59
Could be weak heads as well.
http://www.rescue-it.se
PostPosted: February 19th, 2015, 11:23
Have tried to stop reallocation events in terminal and to close smart feature?
My firmware database:
PostPosted: February 20th, 2015, 5:41
Thanks for the tip michael.
PostPosted: February 20th, 2015, 5:42
Hope it works for you. :wink:
PostPosted: February 20th, 2015, 6:33
I solve the problem, wasn't smart events but that gives me a idea to turn off other events runing backround of the System file in Service Information Objects and it works.
Drive is imaging data now :)
PostPosted: March 5th, 2015, 13:37
Hi infofaster,
I'm a newbie with PC3K-E and I've the same problem with a STM3250310AS can you tell me how I've solved your problem? thx
PostPosted: March 19th, 2015, 15:36
if you new you probably have 1 year TS from ace lab. use it !
Users browsing this forum: No registered users and 73 guests
