 Post subject: WD 10TMVV-11TK7S1 PCB failure
PostPosted: March 17th, 2015, 5:44
WD 10TMVV-11TK7S1, due to PCB failure I replaced it with a donor PCB with same part number(which used to recover another HDD by bypassing USB & wired SATA connector, worked fine in that case) and transplanted U12. The problem is, windows 7 detects the drive correctly , visible the drive without contents in "Computer", after 2 minutes drive disappears from device manager(we can hear a single click at that time). If we disconnected and reconnected the scenario continues. Please help me. Thanks in advance.
 Post subject: Re: WD 10TMVV-11TK7S1 PCB failure
PostPosted: March 17th, 2015, 7:22
Once it showed the volume label & storage usage in "Computer", but after that single clicking sound drive disappeared(after around 2 minutes...
PostPosted: March 17th, 2015, 7:24
Thanks lindakoft...tried it but nothing wrong with its contacts...
PostPosted: March 17th, 2015, 10:03
Arent those hard drives using SMARTWARE? U12 change is not solving problem in case its only a PCB failure. Do you have pc3000 ? I recommend to test heads.
Recuperacion De Datos Dominican Republic
PostPosted: March 17th, 2015, 10:26
Sounds like there are other issues, firmware, likely bad sectors.
How did the native PCB fail? What was wrong with it?
PostPosted: March 18th, 2015, 1:59
@DRforensic ,SMARTWARE didnt installed in it...I don't have PC3000...
@labtech , somebody else tried to repair the native PCB, I got it in tampered condition. My donor board working fine in another HDD, part number & everything same, after U12 replacement through SATA wiring now its detecting correctly, displays the drive in "Computer" with storage usage information along with the drive letter(530GB free of nine hundred something). If we clicked on that drive to open it, after waiting around 2 minutes drive disappears from device manager.
Thanks.
PostPosted: March 19th, 2015, 10:31
Mhhh, since native PCB was tampered with, then I can't tell with a lot of certainty what the original problem may have been, but for me, I tend to believe the PCB was not the real/main problem, rather something else, internal, like bad heads, possible firmware, likely bad sectors, etc.
Needs to have better drive control and as is, with wiring, don't think that can be maximized.
PostPosted: March 20th, 2015, 1:01
Thanks labtech..But the drive detects correctly for a while and the volume label & drive size displayed is ok, so no chance of head failure I think, is it correct? Any firmware update for this model?
PostPosted: March 22nd, 2015, 17:48
95% not.
You are going about this the wrong way.
IF
tobyinbox wrote:
..the drive detects correctly for a while and the volume label & drive size displayed is ok
THEN why would the drive need a firmware update?
PostPosted: March 23rd, 2015, 0:51
Thank you labtech..So ur opinion is head failure...
Anybody having PC3000 here in Kerala state of south India? Pls help..
PostPosted: March 24th, 2015, 13:34
Did you make an image of that drive?
www.datarecoveryne.com
PostPosted: March 24th, 2015, 16:06
The partition table or the data the operating system needs to mount the drive and read it might be on a bad sector, so the hard drive loads as normal, then when you click on computer to read the drive, it crashes on a bad sector and the drive becomes unstable...
PostPosted: March 25th, 2015, 1:18
harddrivespecialist , No, without mount my partition how can I do image?
ShaneWard, So what to do...?
Thanks.
PostPosted: March 25th, 2015, 1:56
A 2 minute delay before a single click would be consistent with the drive autoparking its heads after an APM idle timeout. That said, I would think that the drive should not disappear from Device Manager when this happens.
Try reading the drive's firmware modules with SeDiv:
http://sediv2008.narod.ru/Easy3.9Passwo ... 567890.rar
http://sediv2008.narod.ru/Settings.rar
SeDiv WD Read ROM & Modules:
https://www.youtube.com/watch?v=9UgFfhkkAwY
I would also examine the SMART report with a tool such as CrystalDiskInfo.
http://crystalmark.info/software/Crysta ... dex-e.html
Look for reallocated, pending, or uncorrectable sectors.
Does the raw value of the SMART Load/Unload Cycle Count increment after each click?
PostPosted: March 25th, 2015, 10:07
Thanks.
Use imaging software/hardware.
PostPosted: March 25th, 2015, 10:28
if you don't own hardware
i would recommend ddrescue or dd_rescue, dd_rhelp
Users browsing this forum: Google [Bot] and 284 guests
