 Post subject: Hitachi 1TB Hard Drive Beeping
PostPosted: March 19th, 2015, 17:13
Hello Guys,
Hi have an Hitachi HCS5C1010CLA382 1TB that fall down 2 days ago. After falling down, stopped being detected by Windows.
When i turn it on i can ear it starts spinning but then starts to beeping exactly like user Yello shows in:
https://dl.dropboxusercontent.com/u/25666483/Memo.mp3
I have a lot of documents and photos that i really need to recover... does the noise give any clue about what the problem might be??
Thanks in advance for the help.
 Post subject: Re: Hitachi 1TB Hard Drive Beeping
PostPosted: March 19th, 2015, 17:39
It's either heads stucked to the platter or bent axis, not a DIY
Contact member Zebong, he's from Portugal.
Bosse
http://www.rescue-it.se
it's beyond DIY, send it to a pro DR
PostPosted: March 20th, 2015, 2:39
Bad heads and/or media damage.
NOT DIY :-(
PostPosted: March 20th, 2015, 5:38
Thank you very much for your quick help!
Can you explain why do you say that it is not DIY? :(
If it is a clean room job i have access to one where i study so that part wouldn't be a problem...
Also about that, i opened the disk in that clean room and the heads are moving and the disks seems to be ok (at least the top one).
Also, by the sound, do you think that turning on the disk is damaging it even more ?!
PostPosted: March 20th, 2015, 6:28
Because you need to have experience, proper tools and know-how to swap heads on an HDD. No offense, but you seem to have none of them.
Unfortunately, a clean room is not the only thing that is required.
Yes.
