 Post subject: Trouble reading Micron BGA-152 Chips
PostPosted: April 15th, 2015, 21:57
Is there some trick I don't know about for reading Micron BGA-152 chips with NR/FE?
I've tried reading @ 3.3v & 1.8v, also tried converting the 3.3v signals to 1.8v.
Donor PCB's all use 1.8v..
There are always random groupings of uncorrectable bit errors..
Recover My Flash Drive
 Post subject: Re: Trouble reading Micron BGA-152 Chips
PostPosted: April 16th, 2015, 3:31
NR is not so good for modern memory flash. Many many reading errors.
PostPosted: April 24th, 2015, 14:46
I get same thing with Micron BGA-152 chips. PC3k, FE, and i even tried on VNR where you can control the various voltages but i get same results no matter which power scheme used.
PostPosted: April 24th, 2015, 16:46
@wksk - can I check this via TV? You can contact me on PM.
PostPosted: April 24th, 2015, 20:20
I am about to read one today - will report on how it went.
PostPosted: May 7th, 2015, 7:34
Did you use ReadRetry?
PostPosted: May 7th, 2015, 8:20
The BGA I read - with 2 different tools, had bit errors as well, spread over the dump though.
Users browsing this forum: HannsGruber and 100 guests
