 Post subject: checksum?
PostPosted: April 25th, 2015, 23:18
Hello there ,
Im a newbie .. Sorry for my question. Experiment..
I try to read the ROM chip 8 pins of both hard drive S93C76 in the Hitachi Hard drive ..
Hitachi model HDP725032GLA380 and try to edit serial number on hex .. but after I write back on my hard drive
Hard drive wont start .. is there any checksum needed?
Even I edit 1 Character on the Serial the Drive wont start .. but if I write back the Dump the unit will work again ..
Regards,
 Post subject: Re: checksum?
PostPosted: April 26th, 2015, 0:38
Yes, there is a checksum.
I suggest you do this:
    Read ROM and NVRAM
    Enable PUIS (Power Up In Standby) using HDAT2, hdparm, Hitachi Feature Tool, etc
    Read ROM and NVRAM again
    Disable PUIS
    Compare the before-and-after copies of ROM and NVRAM
If you upload both sets of data, I'll help you find the checksum and recalculate it. That said, I suspect that the drive will spin up, but will probably not give you access to your data due to a ROM/SA serial number mismatch. But that's only a guess.
PostPosted: April 26th, 2015, 2:45
    Read ROM and NVRAM
    Disable PUIS
Hello there ...
Here is the files ..
Thanks for assisting me ...
Regards,
File comment: here is the files
Slave Harddisk S93c76 16bit.rar [1.92 KiB]
Downloaded 568 times
PostPosted: April 26th, 2015, 3:41
    Read ROM and NVRAM
    Disable PUIS
PostPosted: April 26th, 2015, 7:41
The problem is I only see 1 chips. aside the 2 bigs IC.
the other is blank ...
PostPosted: April 26th, 2015, 12:59
Very Informative sir spildit ..
which one is more easy to manipulate of these drives?
Hitachi / Samsung / Toshiba
cause they only accept the Hard Drive of these 3.
PostPosted: April 26th, 2015, 13:15
When I check in the SETUP Menu of this Device .. HDD Serial Displayed 32 HEX..
My Working Unit is ...
" 80BB2F490D51AE87908F4E5237CEE643 "
when I try to change the Hard Drive and this will change ..
I dont know where the Device get this ..
Thanks ..
PostPosted: April 26th, 2015, 13:28
Just read the NVRAM then.
PostPosted: April 26th, 2015, 13:30
As Spildit has said, you can make a WD drive look like other drives using HDDHackr or other tools.
PostPosted: April 26th, 2015, 13:59
Spildit wrote:
Do you know the ATA command to set PUIS on and PUIS off ? (Register status to do it) ?
    Set Features EFh/06h - Enable the PUIS feature set
    Set Features EFh/86h - Disable the PUIS feature set
    Set Features EFh/07h - PUIS feature set device spin-up
The Subcommand Code is placed in the Feature register. In MHDD you would use a line like ...
    regs$ = 06 00 00 00 00 00 ef
There are two ways to spin up a device that has powered up in standby. One is to send any read or write command. The other is to send the Set Features EFh/07h command. Bit 6 of words 83 and 86 of the Identify Device data block determine whether the drive requires the EFh/07h command.
If using HDAT2, just launch it with the /w modifier to wake up the drive, ie ...
    HDAT2 /w
Spildit wrote:
Apart from PUIS what do you think it's stored on the NVRam that I could change on the drive config to the NVRam change as well ? What sort of configuration (that can be set on the drive by ATA) is stored on the NVRam ?
I can't think of any ATA setting, but if your tool allows you to change the serial number, then we could use it to better understand the NVRAM structure.
PostPosted: April 26th, 2015, 14:16
Why do you want to change serial? Want to crack software? Want to cheat on warranty claim?
PostPosted: April 26th, 2015, 14:23
No sir ...
Just use for the Repairing Media Device . that without support from the seller ...
to save neighborhood media device ..
PostPosted: April 26th, 2015, 14:36
Spildit wrote:
I've just changed my serial :)
The Serial is stored after the IDNT module on the firmware but there is no pointer to it on the USAG list.
I've changed my drive serial by appending "SPILDIT" at the end, and it works just fine. This is independent from NVRAM and the drive works with the new serial even if the NVRAM is still the same (it's not changed).
What tools you are using ?
PostPosted: April 26th, 2015, 15:09
Deleted
JammerOne wrote:
No sir ...
What media device is it?
PostPosted: April 26th, 2015, 15:50
On closer inspection, the number in NVRAM is not the serial number that is reported by the drive. Furthermore it appears that, at least in some Hitachi/IBM models, the PUIS flag may be stored in "ROM" rather than "NVRAM".
PostPosted: April 26th, 2015, 20:53
Hello sir ..
It is Easy Sing Mk8504 Sing along Video Karaoke HDD System..
PostPosted: April 27th, 2015, 5:25
Have you tried contacting www.multak.com ?
JammerOne wrote:
No sir ...
PostPosted: April 27th, 2015, 21:45
guru wrote:
Have you tried contacting http://www.multak.com ?
JammerOne wrote:
No sir ...
Yes sir.
But they tell me to buy their New Product .. (They introduce new Product and Marketing Strategy)
The old are all working aside the Hard Drive Defect ... after we replace Hard Drive and all be fine,,,
Thanks ..
PostPosted: April 27th, 2015, 22:15
Why would a manufacturer of a Karaoke machine want to "protect" the HDD, except to prevent a user from purchasing his own "optional" accessories?
http://www.a4u.ca/ifun/MK8504%20Highlight.htm
Seems like planned obsolescence to me. Kudos for trying to keep working equipment out of the landfill.
Users browsing this forum: No registered users and 266 guests
