 Post subject: [HELP] HDD Spins up with a noise
PostPosted: April 27th, 2015, 5:53
My HDD is an old Hitachi Deskstar IDE drive.It spins up and produces a noise, I have opened them, the head is not stuck.
I have an 2 Videos of how it is rotating one normal and the other Zoomed , I have moved the head into the platter and taken three photos one normal
and 2 Zoomed. The sharp par is slightly lifted in the image.Can any on tell me the reason
http://goo.gl/zb7EU9
 Post subject: Re: [HELP] HDD Spins up with a noise
PostPosted: April 28th, 2015, 5:16
I hope this is a drive you wanted to experiment on and learn, and not a drive that contains important data...
PostPosted: April 28th, 2015, 8:22
By opening the drive outside of a clean room and moving the actuator arm onto the platters you've dropped you chances of ever getting the data back from 80℅ to about 10℅.
PostPosted: April 28th, 2015, 9:18
Spildit wrote:
The noise that you can ear is from your data trying to say it's last good bye while it turns intro dust...
PostPosted: April 30th, 2015, 4:08
Its is a very old Hard Drive, I have Two Exactly same HDD with same problem, I wanted to experiment with one, There not really any data in it, just wanted to know if that can be revived.So I can make the other work.
if it helps it is an 2004 DOM HDD.
PostPosted: May 1st, 2015, 1:17
if it helps it is an 2004 DOM HDD.[/quote]
:shock: :oops:
Users browsing this forum: No registered users and 208 guests
