Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: WD5000BUCT-63PUZY0 \ ROM damage
PostPosted: April 30th, 2015, 3:23
Hi members,,,
I have HDD laptop 2.5' ,after I connect it, the spindle doesn't work at all
after diagnosis, the problem is ROM damage, after change the ROM, the HDD become works with cliking noise because ATA/ ROM dosen't match,
The question is, How I can make the new ROM adaptive "ATA/ ROM adaptive" , to be able to browse modules
note/ I have SD tools
Expect, the Unexpected
 Post subject: Re: WD5000BUCT-63PUZY0 \ ROM damage
PostPosted: April 30th, 2015, 3:49
how did you figured it's the the rom ?
it can be bad heads, preamp, or damage SA
edit: giving the situation i would vote for preamp
PostPosted: April 30th, 2015, 3:50
is ROM is physically damage ?
did you try the original ROM with Donor PCB ?
did you try to read the original ROM with programmer ?
I think SD tool has this option to build ROM from SA, but you have to reach SA first.
you need a closet drive's pcb to reach SA, backup all modules and build the original from backup data.
RAID/Server Recovery
PostPosted: April 30th, 2015, 4:07
Hi jermy
I know it's ROM damage after I done that
I change the PCB with another PCB have the same number, the spinde work up but when I replaced the orginal ROM to the new PCB the spindle doesn't work at all
the Hdd doesn't drop,and if the HDD have bad heads, preamp, or damage SA, at least the spindle work up when I connect to the power.
PostPosted: April 30th, 2015, 4:14
Hi chinopk,
No physically damage appear,
I'll try that
If I doesn't have a closet drive's, are they any another way to to reach SA in order rebuild ROM from SA
PostPosted: April 30th, 2015, 4:34
even if it doesn't dropped, these problems can occur.
it's not about a closest drive it's about a matched PCB
PostPosted: April 30th, 2015, 4:46
even I a matched PCB without the orginal ROM, you conn't access to SA, there are another parameter should be the same on HDD in order to access to SA
PostPosted: April 30th, 2015, 4:56
exactly, a closest drive will have a good matched PCB. .. :)
PostPosted: April 30th, 2015, 5:40
Is this another PUIS case?
PostPosted: May 2nd, 2015, 6:25
Spildit wrote:
Can you post a dump of the original ROM ?
If you post a dump of the "damaged" ROM i can confirm if it's really damaged and hopefully copy the ROM modules to rebuild the original ROM.
If that is not possible a copy of the same version should allow you to access SA, then you just have to rebuild ROM modules by using the data on the SA copies.
Hi Spildit
Sorry for late, I upload a dump of the original ROM
https://www.mediafire.com/?o2kaz418fo2lymd
I'm looking forward to your reply
PostPosted: May 3rd, 2015, 1:23
Spildit wrote:
Can you please upload it to somewhere where i can donwload it without having to create an account ?
I'm not able to download it from mediafire. Just zip/rar the ROM file and upload it here at the forum.
Gladly,, the file in the attachment
ROM.rar [222.69 KiB]
Downloaded 473 times
PostPosted: May 3rd, 2015, 4:58
Can you upload the donor ROM so that we can compare?
PostPosted: May 3rd, 2015, 7:05
Hi fzabkar,,
I attached the two files
ROM- Donor.rar [228.22 KiB]
Downloaded 344 times
ROM-Patient.rar [222.57 KiB]
Downloaded 342 times
PostPosted: May 3rd, 2015, 9:19
The patient and donor ROM dumps both have the structure of a WD ROM, but neither has any intelligible data. How are you reading these ROMs?
PostPosted: May 3rd, 2015, 12:11
IMHO he is using SD, as the OP wrote @ the beginning
eng.mas wrote:
I have SD tools
and something is wrong with that
PostPosted: May 3rd, 2015, 15:29
Try reading the ROMs with the demo versions of SeDiv or WDR, or preferably with a chip reader. If the patient drive is detected in BIOS with its original ROM, then I suspect it may be powering up in standby (PUIS). If so, then that's an easy fix.
PostPosted: May 3rd, 2015, 19:47
I suspect that the heads are toast; there is media damage; and the ROM is OK.
http://www.datasaversllc.com
PostPosted: May 3rd, 2015, 20:08
ISTM that the donor ROM must be OK since it is able to spin up the drive. The problem appears to be that the [OP's unknown] tool isn't dumping it correctly.
Furthermore, even with the strange dumps, both patient and donor ROMs have a similar structure. I still suspect that the OP may be seeing a PUIS issue, especially if the patient PCB + patient ROM identifies in BIOS, albeit with zero capacity or a blank model number. An Identify Device dump with a tool such as CrystalDiskInfo would confirm this.
PostPosted: May 4th, 2015, 2:25
Thank you fzabkar,Spildit, and jermy for your interactive,,
I read the ROMs with the SD tools "flash programmer in WD utility"
I think it's possible something is wrong with reading, because I 'm sure the Donor ROM is working, I take it from working HDD
I'll try reading the ROMs by another way such the demo versions of SeDiv, but I did'nt use it before.
PostPosted: May 4th, 2015, 2:59
Dear fzabkar
When I used the patient ROM on PCB the spindle of HDD didn't work at all, so with this can identifies in BIOS?
