Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject:
PostPosted: November 24th, 2004, 6:53
Very important that all are checked
 Post subject:
PostPosted: November 24th, 2004, 10:31
Ok, I have no checksum flag for #01 04 12 14 2D 2F 30 41 42 45 46 47 63 64 67 70 71 80 82 92 9C A3 A4 A6.
What I can do ?
 Post subject:
PostPosted: November 24th, 2004, 19:13
Vostanovlenie modul
 Post subject:
PostPosted: December 8th, 2004, 5:38
Hello ppl, couole of days ago, i've had a problem with an N40P, similar to the one fujimax had. i think i tried evrything with PC3K, but until i change the r/w head, the surface looked like XA! in mhdd. Hope this helps
DE AD
 Post subject: Re: MAXTOR - Anyone seen this before ?
PostPosted: December 11th, 2004, 20:17
fujimax wrote:
Today worked on 2 Ares.
Both were (BAD!) - - - for plist, glist and dmcs
and copies all bad - fixed this, but...
One drive recovered files and then...
2nd drive, data seems OK to about sector 4.8M
thereafter all sectors filled with identical 512 sector to
end of drive !
In drive write enable I was able to record and
read data correctly to/from some test sectors.
Any ideas. ?
If you have Data Extractor, try using it. It might take a while, but in most cases you will find that DE gets all the data from the drive.
