Spildit wrote:
This is crazy !!!!
People can't use the on-line version because ... the server is down ? So if i pay for some time of use and the server goes down ... i can't use the tool that i've paid for ? What if MRTLab "disapear" from one day to another ?
I've used some PC-3000 UDMA units and there were no problems like this, (ok, they don't have on-line versions and they don't use the internet unless you change the card to another machine) on PC-3000 UDMA if you force the app to close for some reason, like using CRTL+ALT+DEL when you open the app again you don't have to re-install the software.
I've used my HRT card on 4 different machines so far, from P4 to dual core and even on machines that are not that powerfull i never got a single crash so far (unless i do something really stupid like attempting to read the buffer on a data request when i have to send data instead). On those cases the app closes itself but i open it again and runs normally withour re-installing anything at all.
Well, one of the things that i really like on the SD tools and on the BVG HRT tool is that the license activation is done on the HARDWARE and there is no lock to the machine.
If you move a PC-3000 card from a machine to another you have to re-activate it. Sediv products the same, and you have limitations on activation. MRT as well.
One good thing about SD is that once you activate your device the device itself stays active and you can use it on any machne you like. Same for HRT, you activate the tools on your card and if you want you can move the card (and you just have to install the drivers) and it will work ....
My problem with things like PC-3000 and MRT license is that if one day they go off-line and no longer exist and you need to move your card to another mavhine ... you are in really big trouble ...
And again, MRT is NOT a $500 usd pc-3000 clone.
For a $3000 USD tool you would expect some more reliability .... And at least to be able to use the tool even if it have some bugs ...
Now if the cards start acting like this and MRT doesn't respond quickly and even so start banning people from the forum who complain .... I really would by no recommend for people NOT TO BUY the tool untill this mess is sorted out.
There are still alternatives like Atola, DFL, F.L.A.M.E., etc ..
For a cheap GOOD alternative SeDiv is good too.
Well to answer All your questions ,
First Good morning spildit .Here you goo....
1 : People can't use the on-line version because ... the server is down ? So if i pay for some time of use and the server goes down ... i can't use the tool that i've paid for ? What if MRTLab "disapear" from one day to another ?
Ans : Well thats the way it is but in the 23 months period it gets converted to offline
2 : I've used some PC-3000 UDMA units and there were no problems like this, (ok, they don't have on-line versions and they don't use the internet unless you change the card to another machine) on PC-3000 UDMA if you force the app to close for some reason, like using CRTL+ALT+DEL when you open the app again you don't have to re-install the software.
Ans : Same is the case with MRT Provided You have a good Card .The Card The One Thats Works Works Exactly Like This
3 : I've used my HRT card on 4 different machines so far, from P4 to dual core and even on machines that are not that powerfull i never got a single crash so far (unless i do something really stupid like attempting to read the buffer on a data request when i have to send data instead). On those cases the app closes itself but i open it again and runs normally withour re-installing anything at all.
Ans : Same Reply As Above
4 : Well, one of the things that i really like on the SD tools and on the BVG HRT tool is that the license activation is done on the HARDWARE and there is no lock to the machine.If you move a PC-3000 card from a machine to another you have to re-activate it. Sediv products the same, and you have limitations on activation. MRT as well.One good thing about SD is that once you activate your device the device itself stays active and you can use it on any machne you like. Same for HRT, you activate the tools on your card and if you want you can move the card (and you just have to install the drivers) and it will work .My problem with things like PC-3000 and MRT license is that if one day they go off-line and no longer exist and you need to move your card to another mavhine .you are in really big trouble .
Ans : Yeah We All Love SD Tools HRT i Do Not Have
.I still have Seagate ,Hitachi And Maxtor SD Doctor
5 : And again, MRT is NOT a $500 usd pc-3000 clone.For a $3000 USD tool you would expect some more reliability .... And at least to be able to use the tool even if it have some bugs ...
Now if the cards start acting like this and MRT doesn't respond quickly and even so start banning people from the forum who complain .... I really would by no recommend for people NOT TO BUY the tool untill this mess is sorted out. There are still alternatives like Atola, DFL, F.L.A.M.E., etc .For a cheap GOOD alternative SeDiv is good too.
Ans : Well in My case i would say and defend myself that i did nothing in the forum that should invite a serious issue like a ban .I am not a kid reaching 40 years now .Well As Far As I say say i fully recommend the tool but not the way they handle things ,Thier english team should be expended and response time has to improve .
Website->
http://www.chandigarhdatarecovery.com
