 Post subject: Seagate SSHD 1000GB LDR need
PostPosted: May 5th, 2015, 4:15
Hi
I need LDR for Seagate SSHD 1000 GB.
Model = ST1000LM014
Serial first three digit = W38
Firmware = HPM2
PN = 1EJ164-020
Waqas Ali
 Post subject: Re: Seagate SSHD 1000GB LDR need
PostPosted: May 7th, 2015, 1:18
I have one, but with other Firmware.
i have forgot the notice at home, i remeber me only at:
PN = 1EJ164-500
Serial W38...
Frank
PostPosted: May 7th, 2015, 11:27
hi,
Firmware no need match, send me LDR file if you have
Note : My hdd is seagate .
this same model also available in samsung hdd.
Waqas Ali
PostPosted: May 8th, 2015, 0:15
So now i can corrected.
Firmware: SM11
I can send it at the earliest on Monday. This is my private HDD and I need to expand only and they bring with me to work.
Frank
PostPosted: May 11th, 2015, 2:13
I get several errors appear, when i reading the loader. see attachment.
loader has 0 byte.
any ideas what i can can try?
Frank
ST1000LM014-1EJ164.log [10.4 KiB]
Downloaded 612 times
PostPosted: May 11th, 2015, 7:25
If you are trying to create loader with PC3000 it will fail because PC3000 cannot properly support SSHD drives. You need to read overlays needed as system files then manually import them to a previously created loader from a non-sshd drive.
PostPosted: May 11th, 2015, 7:54
i'm sorry, but so deep I put not in the matter.
Users browsing this forum: Google [Bot] and 43 guests
